Do take note that this is not Olight. OTR has been around since 2014 if I am not wrong. Their flashlight build quality is good, but their product prices were relatively higher back then. Read RaceR86's review for X6M flashlight https://budgetlightforum.com/t/-/25997 if you are unfamilar with this brand.
If this GBGB is successful, I am sure vendor will definitely bring in more models later on.
I should receive the light in about a day time. Stay tuned.
It would be disappointing for easy modding to have it a press in bezel. Not unworkable, as you said earlier, just harder. I nodded my S1 Ti following member X3’s guidance and a video from another member. I used the PVC pipe cutters, then found the rotary tubing cutters (looks like a C-clamp with rollers on one end, blade wheel on the other) works very well to when changing emitters again…
I do like the size of the S1, but if this thing is a little bigger, as it appears, then this will become a triple for me…
Put me down for one more 5C, come to think of it… Always need a backup…
M3 does not accept 18350. It is modeled closely as Olight S10. Bezel is not glued, and can be easily remove with a pair pliers. Reflector is screwed into the aluminium pill like Olight. Same as Olight, triple conversion will not be as direct as we hope for.
