ENEDED
Driver easily removable?
I will leave the driver intact till I finish all my beam shots and measurements. From the back of the view, I suspect it adopts the same driver layout as Olight below. OTR M3 has stated integrated pill design in their description.
Credit: wet
Looking forward to your impression of the tint as all as the beam shots!
Hopefully it is clearer now.
i just measured my olight s15r and blf A6, both had moonlight modes of 3 mA and next level at 25 mA, so this one has a brighter ultra low then.
nice flowchart for the ui!
it always starts in ultralow when long-pressing, and you get access to turbo and strobe by double/triple clicking.
Beamshot photo please!
And compare it to a few of the lamp brightness to what you already know everyone. Thanks!
This is ultra low is 10mA. It is slightly brighter than moonlight but it still pretty useful in my opinion.
There is on time memory (<3s) for the four brightness level. It will only start from ultra low by default when memory is cleared. (e.g disconnect power from circuit - you remove and re-insert battery into flashlight).
I am out if it doesn’t always start in low or ultra low.
Please add 2 more lights to my previous order for 1, subject to your test/review.
Will there be an option & discount for the “gift” set which includes the battery and charger?
Put me down for 1 more 5C…
Thanks
Still trying to figure out why this has not taken off…
A 5C option!
Nice solid body with a screw in bezel…
Decent UI from the looks of it…
No visible PWM it appears.
Magnetic Tail Cap…
Nice looking anodization…
Come on people! I ordered one from the special with the battery and everything, when it comes in, I will post my impressions here…
I am not sure either… basically no PWM, good tint, good modes, magnet, decent clip. I am not sure why nobody is jumping in on this one. This is basically the cost of 3 emitters. Looks like the LED is easy to change, the UI looks pretty good. I think it will make a nice EDC. I wonder if it could be reamed out to take an 18350?
It could be that nobody recognizes the brand “On The Road”. I discovered this group buy when some asked on Reddit if this flashlight was an Olight clone, and then I did some google searching for it.
I pm’d freeme for a pair of them
True, I did like that it is a little larger than an S1. We all like our S1’s, but a bit more size goes a long way and this one should be pretty sweet in size. Not to big, not to small…
I am hoping to figure a way to put a triple in this, just for fun of course, but if not, it looks like a standard 20mm optic will fit and provide options for floodier beams if that is what you like (I do).
Brand is less of a big thing if it is made well, I picked Thorfire by comparing them to a Convoy, did not do too shabby for my first C8, but that was because I knew what to look for from reading BLF before I made an account…
I would like it if there were a way to disable mode memory. I like a light to start the same each and every time I turn it on. I prefer starting on low. I’ve got buckets of lights that I never use because of the memory. It just took me a long time to figure out what I like.
I would help you thin those buckets! I like to always have memory, if I want to start in a given mode, I just shut it off there.
Warm and rosy 5C. Review is almost done.
One 5C
I’ll take 2 with 5C tint
