What I want to do is that you have explained. I have modified the code that
FULL BATT indicator off
LOW BATT indicator on
ALMOST EMPTY indicator blink
As you have said, the led flickered before it was stably on. I try to get rid of the flickering. It seems that is not easy to be done by changing a few lines of the code.
ive been playing around with tk’s starry-offtime firmware(and others). Does anyone know where i can find the .h files that are referred to in the STAR firmware? Or do i not need them? Thanks for any help! These are the files i am talking about:
PPDB22, they are installed with the “avr-libc” package on linux distributions. Not sure what the equivalent is on windows. If everything is installed correctly, they should be found automatically by the compiler.
I’m on Windows 10. I’ve only flashed four drivers so far. I asked about these files because I compiled a different firmware with errors caused from missing files. I fumbled through fixing that so when I came to this firmware and saw it referenced some files I went looking for them. Thanks for you help. I’ll get to try it out tonight if my day goes well:)
i have been preparing myself for using the triple down drivers for some lights to spot game at night. So I was thrown off a bit when I was asked to build some lights with red emitters. Anyway, I searched for some code for 7135 drivers that could be modified with an “off” mode as well as battery check mode. Ironically, the code I now have working is tk’s s7 firmware which is designed for advanced flashy modes. It now has five modes, off-low-med-high-battcheck, and memory is disabled. So from any mode I can turn the light off and then back on again without a “click”. I’ve found the click from a tailcap switch to carry quite far in the still of the night. I will be curious to see if this is helpful or not.
Thanks to tk and the other firmware builders!
I’m after a bit of help. I have a MTG2 light which is causing me a bit of a headache. The LVP kicks in really early, I have the right voltage dividers and I’ve tired getting the readings with TK’s firmware but they just don’t seem to be right. I suspect its down to the voltage drop when the light is pulling high currents. Is there anyway that I can get these readings while there is the voltage drop?
Thanks
Does the firmware you use have some sort of voltage readout ability?
I did some testing with storing the voltage value under load in the no init area and then retrieving it on readouts. It worked ok but I found it rather useless for my purposes. Now I have it so that when boost mode is active the LVP step down kicks in at critical voltage level, not low voltage level.
No I don’t have a readout on the firmware I’m using but willing to look into those that do as it is driving me mad. It makes the light unusable as it just steps down as soon as it get into a high mode.
What MCU are you using? If it’s 13a based I can’t help much with code, I haven’t touched that little thing in a long time and have no code for it left.
Another thing that might be affecting your readings: The internal 1.1v reference voltage is different on each MCU. Datasheet specifies it can be between 1.0v and 1.2v. Normally it’s very close to 1.1v and nothing needs to be done, but I have had the odd MCU where it has been at the very limits. This caused readings to be off enough that I wrote a calibration routine.
May I ask what driver you have, and what the values of the voltage divider resistors are?
If you have a working 85 firmware that has some sort of readout function it could be modified to write the voltage value to EEPROM or no init area. I can give small tips on how to do that but I won’t make a whole flashable firmware as my hands are full with getting my own firmware ready.
I have no experience with Toykeepers firmware so I can’t really help with those readings that appear wrong either.
Did you actually measure the resistors of the divider? What are the values? If you’re unlucky and they’re both 5% off in the wrong direction, you’ll get a reading about 10% off. That’s over 0.3V.
Also, what is the LVP set to in the firmware? I mean the actual ADC value (something around 100-120), not what the comments claim the voltage to be.
I’ve always had trouble with LVP on my 2S lights, to the point I don’t even bother anymore. I figured out the correct resistors to use (don’t have those values in front of me right now), then hooked up my power supply (which works great for 1S LVP) at 6v and recorded the values to put in the FW. The values were were right in the middle of the usable range, but without fail as soon as I assembled the light, the LVP would kick in at like 8v instead of 6v.
I suspected my cheap power supply was causing me problems so I bought a 6v lantern battery which I slightly discharged till it was exactly 6v, and used that to calibrate the values. It made no difference at all. I had this problem with 3 different drivers, different pcb designs, different value resistors, it never worked.
OK so I haven’t used this torch for a while and last time I powered it with 2x NCR18650B for long run time. This time I’m using 2x 30Q and I’m not suffering LVP problems, managed a whole 120 seconds turbo time (never happened before). So I guess the high discharge batteries don’t voltage sag anywhere near as much and that was the cause of my issue.
Scrap that. Its defiantly better but they just got to 7.9v and now LVP is cutting in. I think I’m just going to have to do this on by eye.
Using the 2x 30Q has caused me another issue, the springs aren’t long enough now.
