Use the lens to replace the relfector of Convoy S2+ flashlight
42 posts / 0 new
rollinstone157
scooby214 wrote:
I have a Carclo 10003, but was disappointed with the result. I tried it with and without the holder, and couldn’t get as nice of a beam as I could with the one I got from LED-DNA. The beam ended up taking on the square shape of the emitter most of the time. I’ve heard that they work pretty well if you can get the focus right by using the right combination of spacers. It certainly wasn’t a simple drop-in upgrade for my S2+. I didn’t try any of the other Carclo optics, as the 10003 had the tightest beam of any of the Carclo optics I found easily obtainable.
Huh. Well, I’ll see what I can do and post up the results! I ordered the 10003, -15, -25, and the -L25.
scooby214
Last seen: 1 year 11 months ago
Sweet!
arekm
Last seen: 10 months 3 weeks ago
WarHawk-AVG wrote:
Awesome!
Need a spacer on the pill…the optic is shorter than the reflector..need to make up about 1/4” to 3/8”
- edit – I stand corrected the S2+ pill is longer than the S2, the reflector of the S2+ is shorter than that of the S2 so you don’t need a spacer, only on the S2 do you need that spacer
For S2+ and stripe lens – the lens was loose (tested in two different S2+; doing exactly the same as on video in this thread). Used additional o-ring on the front (https://www.fasttech.com/p/1088604; so two in total since there is one already there) and now stripe lens isn’t loose.
Using additional o-ring also makes these optics fit S3.
BANGGOOD.COM: Track packages (even ‘untracked’ ones) -> https://goo.gl/I8iqFp
Read Me – http://readme.maven.pl
Richwouldnt
Richwouldnt's picture
Last seen: 6 months 1 week ago
Location: Reno, NV, USA, Terra, Sol, Milky Way, Known Universe
Not sure which exact ones he uses but based on the order form it looks like Richard at Mountain Electronics uses some of these lenses designed for the S2 lights for his 3 LED Triple XP-G2 high output “S3” light. I will know more when the one I have on order arrives. Richard lists the lens option I ordered as the 10511 and describes it as the one most closely resembling a standard reflector beam.
Rich Wood
Reno, NV
NeilP
NeilP's picture
Last seen: 11 months 3 weeks ago
You can get the Carclo line of optics @ LEDSupply for very reasonably prices (<$1.50) apiece and free shipping in the US. I imagine the quality is superior. I just picked up a little variety to see how well they perform!
Why do you find the square pattern a problem? I happen to thing it is really good. and from my understanding that is about as tight as you can get.
I am wanting to get a Convoy Sx X being 2 2+ 3 4 5 6 or 7
From Jersey, the Island, not New Jersey, but old Jersey..the real one Wink
mattlward
mattlward's picture
Last seen: 1 week 6 days ago
I am going to convert one of the above to a 219B light. I think I would like to add a 10 degree to this light, but the LED’s are a different size. Would I be locked into using a Carclo in this combination?
Thanks Matt
EDC rotation:
Convoy S2+, 6*7135, XM-L2 3D, 10 degree TIR, PilotDog lighted tailcap.
Convoy S2+, H17F, XM-L2 4C, lighted tailcap
Zebralight SC52w-L2
Olight S1A
Olight S1R
Techno
My Convoy s2+ came in today. Managed to install the TIR lens from LEDDNA. It fits nicely, did not have to trim the white holder. Merely pushed the thing in with a little force.
EasyB
Last seen: 1 day 14 hours ago
I just installed a 10 degree TIR from LEDDNA in my S2+.
http://www.leddna.com/10-30-60-80-degree-lens-for-cree-xp-l-xp-g2-xt-e-x...
The original OP reflector was not great for throw. With an XPL HI V2 3D emitter at around 5A, the throw was 13,500cd with original OP reflector. With the TIR properly adjusted so the emitter image filled the reflector, the throw increased to 21,500cd at around 5A.
I’m very happy with the improvement. It seemed to reduce spill, and also reduced the corona around the hotspot some. So the hotspot is a bit more well defined, but there is still a nice gradient from the hotspot to the spill. The TIR throws about as well as the smooth S2 reflector. With the same emitter with the smooth S2 reflector, the throw was 23,000cd.
It took a little fiddling to get the TIR installed correctly. The white holder it came in was too large to fit in the S2+ head. Also, the bottom of the white holder is flat, so the solder joints on the MCPCB prevent the TIR from sitting correctly. So I had to remove the white holder. The correct focus was achieved when the bottom of the TIR was about even with the surface of the XPL HI, so an appropriate spacer is needed. I cut out the part of the white plastic holder that fit around the emitter and used this as a spacer. The TIR without the white holder almost fit nicely in the bezel of the S2+ head, but with the oring in place the TIR would not sit quite completely level, so I kept the glass lens in place to keep everything level and maintain water resistance.
Terry Oregon
Terry Oregon's picture
Last seen: 1 week 7 hours ago
scooby214 wrote:
The holder needed a little trimming to fit in the host head. A nice thing about using the holder was that it kept the optic relatively centered and focused.
I can concur that the white plastic holder does not go into the S2+ easily. At first, I did not think it would fit at all.
I installed the 60deg optic on two of my S2+. This is the 60deg lens that Simon has for sale here).
My first attempt to install the 60deg was to remove the clear optic from the white plastic housing and then place the optic on top of the original orange peel reflector. This actually worked.  However, once I read this thread, I decided to try and install the entire piece (with plastic housing). On the first S2+, I was able to "screw" down (with needle nose) the white plastic housing (not easy), until it was all the way down.  On the second S2+, I was able to push it all the way down (took some force).
first attempt - optic on top of original orange peel reflector (actually worked). I now realize that's not how it was supposed to work.
Second attempt, I was able to install the white plastic housing as well.  Fortunately, you get five pieces, so there's room for trial & error).
This gives a nice creamy smooth floody beam pattern, just what I was looking for.
Terry Oregon
Oh, and unfortunately, that video that Simon posted never seems to load - so couldn't watch it.
beam0
beam0's picture
Terry Oregon wrote:
I installed the 60deg optic on two of my S2+…………………………………………………..
Thanks for posting and reviving this old thread…read it years ago and forgot about it, I recently ordered the 60 degree TIR’s for an S2+ shorty I’m building (also to try in my Nitecore HC30)
It was interesting to read the feedback here again on the 10 degree spot optic, I have 5 of those plus a 15 and 30 degree I bought back in 2016 (after reading this thread) but I never tried them because I ended up fitting a long SMO S2 reflector into my S2+. That reflector seemed to improve the throw nicely so I left it alone, but I just dug up those TIR’s to give them a try now too.
Here’s a link for the reflector I mentioned:
Deep SMO reflector for S2/S5/S6/S7/S8 (can also fit S2+ using short pill from S2/S5/S6/S7/S8 )
https://www.aliexpress.com/store/product/Free-shipping-Aluminum-Smooth-R...
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
