I got the driver in and without having tried it I’m impressed by the number of settings (my favorite low-med-high-without-memory can be chosen, unlike intl-outdoor’s qlite) and by the good connection between batt+ and led+ . The 7135 chips are branded and look the same as Mtn El. uses. Good to hear that the PWM is unvisibly high.
One more question: the manual speaks about thermal protection (output step-down) which is a great feature, but I know that the Attiny13 MCU does not support temperature sensing. This MCU has its branding sanded off, but is it the Attiny25 or the like that does have temperature sensing?
Question - is that “silver” as in the metal?
Wikipedia:
or does it mean silver as in “shiny” (some other kind of plating, such as chrome, or cadmium, that looks “silvery” but stays very shiny without tarnishing?
The nice thing about silver compared to chrome is, silver won’t flake off eventually
The nice thing about silver compared to cadmium is, silver is not toxic
The nice thing about silver electrically is, silver oxide (tarnish) is still an electrically conductive material
Looking forward to hearing more details when known. The Attiny25, 45, & 85 MCU’s have internal temperature sensors. The 7135’s have an automatic step down when a certain temp is reached (Don’t recall the temp off hand). Guess they could be talking about either.
@KD: I’m interested in this new C8 reflector optimized for XPL HI… Will it be available separately and does it fit other C8 light such as the Convoy and Thorfire?
From the layout, looks like it's not a Atmel MCU - pin #8 appears to be GRND, while the Atmel's have VCC there. Could be PIC based. VCC and GRND is the quick and dirty way of telling if it's an Atmel or not.
ImA4Wheelr is right. AMC7135 will step down if the temperature is reached. For the 8 x AMC7135, that mean we have 8 chips to help to so called heat dissipation.
I would check what is the MCU used in KD 7135 Driver board when i back to office on tomorrow.
The new P60 drop-ins with 4500K Nichia 219B’s and 1.5A driver look great. I have made similar drop-ins, but this is a great option. Perfect for anyone with some underused P60 hosts lying around. A great tint and beam with long runtime from a decent 18650.
The model I have to review has a smooth reflector which helps with throw. If I get an opportunity to gram an OP version to test out I’ll pass on the beam shots and results.
Still looking for your C8? lol the OP will make the beam less of a thrower and it will also give it a warmer appearance I build a C8 with a OP textured reflector like these ones its nice it still throws far but no where near as much as a standard C8 as for power @ 3 amps these will maybe just 1000 lumen nothing spectacular same package as what convoy is offering but it appears that these lights have no centering ring the reflector is custom made to sit on the MCPB i cant tell for sure because no one has to taken pics. Other thing is the driver looks like it is soldered in and doesn’t use a retaining ring…
I’ve started collecting data for the new C8 from KD and the results are great so far. About 70k on the lightmeter at a spacing of 1m. It’s an excellent thrower for it’s size. Best SMO C8 I’ve seen to date. At this time I may not be able to test it with an OP reflector. Once the review is over I may try, but it’s not a simple swapover. I may need an LED gasket. Anyway I’ll explore.
The KD C8 is not a well-optimized use of the XP-L HI. The same ugly yellow center can be seen, and while the throw is great, the beam looks messy to me. Looks like a poorly de-domed XM-L T6.
The only good use of XP-L HI is in the KD P60 drop-ins. No ugly yellow center and great throw.
Rusty are you referring to the newly released KDLIGHT C8 or the earlier versions? The Cool White version I have of the new model has a nice clean beam pattern.
I am referring to the newly released lights. I gave them away to friends. They are functional and bright, but they suck. I now hate XP-L HIs because of the coloration issues. They are really ugly.
