You will not get 1000 lumen out of a high CRI 219b, very well driven it can output a bit over 500 lumen. Unless it is a triple or quad flashlight, but the only stock multi-emitter light is the S41, that you do not like.
Your name sounds like you are from the Netherlands, if so, if you like a particular led you want in a flashlight I could help swapping it in for you?
Thank you all for the suggestions so far, will look into them thoroughly. I did encounter the Lumintop Tool but can’t remember if I had noticed it also came with a 219B.
Apart from the design of the S41 I also get the impression that it runs hotter than the S1. Forgetting about CRI for a moment, which of the S1 emitters would you say comes closest to the perceived tint of the 291B on a plain white surface? 3D or 5A?
I am. Thank you for the offer, very generous and I’ll keep it in mind in case I cannot find a stock light that is to my taste.
I might even end up ordering both an S1 and S41 (unless I can find something that combines the best from both) but I believe the S41 only use 18350s while I’d prefer to use the S1 with 18650s and I’d like to settle on one type. Seems I might be in risk of becoming a flashaholic :disappointed: Does the S41 _require _unprotected batteries to function at all or does it only drop a bit in output?
If anyone has any other recommendations I’m all ears.
P.S. How is the soldering on these lights? I have seen my share of bad soldering in budget (and even not so budget) electronics and it hasn’t gotten any better since the introduction of lead-free soldering paste. Especially if some of it is done by hand for small production runs or other reasons.
…and the other way around: you can get a 18650 tube for the S41 and have a longer flashlight with longer runtime. But for that set-up, perhaps best is using a not too high drain battery like the NCR18650B or you may overheat the light.
Aesthetically I would really have liked this light years ago but these days it seems I’ve taken to the anodized black, slightly knurled look. Perhaps this one is a bit too ‘civilian’ or ‘pen-like’ looking for me (which is something I totally loved as a kid, I had a pen-light back then that took 2 AAA’s and loved it).
The black knurled style looks (and only that) a bit more robust, a bit more heavy duty. Still one to consider though, it looks good in its own way and it does have the 219B. Seems very practical overall and that’s what I’m looking for in an AAA light.
I wonder if any serious research has been done into that. Incidentally I didn’t think a strobe is going to completely get rid of a mugger, but I though that perhaps it might give you just a second or two to proceed and incapacitate him through physical means (or run away if that option is available). On the other hand I don’t see how it’s likely that you’ll have time to get the light out of your pocket (especially if you keep it in your inside coat pocket) and set it to strobe . Probably better to rely upon my martial arts training and get right to business.
I do also wonder how an agressive dog is going to react to 1000 lumens right in his face, especially at night. Dogs may not rely upon their vision as much as we do but it might make it more difficult for them to target you properly. I doubt much research has been done on this as it’s probably not very ethical to do so. On the other hand perhaps police dogs could use some training that involve flashlights shining in their face.
Yup. I can see it might be useful for a cop, that already has his light ready. It could give a second or so of time for him to shoot a bad guy. But unless someone really knows what to do in that second of time, forget it.
I don’t see anything unethical about shining bright lights in dogs’ faces. It just a light, you’re not permanently blinding the animals. From my limited experience, most animals show little reaction to either a constant beam, or a strobe, regardless how bright it is. Sometimes curiosity, but it never stops them from doing something. Much like people, it might buy you a second or two.
The Tool AAA does look nice but I don’t seen an option for the Nichia LED on their website, only the Cree XP-G2 (R5)??? Or it is only certain models such as the Copper Tool AAA and the Tool Ti that are available with the 219B?
While checking out the Tool AAA on Amazone I stumbled upon the Bronte BT01 which looks nice too (no 219B though), is that any good? I think they are exaggerating the lumens though so that might be a bit of a warning sign.
The Fenix LD02 also looks very nice (purely from an aesthetics pov) but again no 219B it seems.
Are any of these (plain Tool AAA, Bronte BT01 or Feix LD02) available with a 219B? Or perhaps with the the xpl hi or XML2 as mentioned above ? I might be willing to compromise on CRI if at least the tint itself is good and the beam a nice even color.
Oh my, that looks yummy! Really like the aesthetics on this one. Very cheap too (although that’s not my primary concern!
In my OP I mentioned I wanted to use protected batteries only but I’ve been reading a bit more about IMR batteries and it appears they are inherently safer chemistry-wise. What is the prevailing wisdom here? And would the Convoy S2+ work ok with IMR batteries?
I watched one of those ‘survival’ programs on Discover or something a while ago and they made fire by damaging a Li-Ion battery from their cellphone. Very agressive stuff what’s inside! I knew that already but seeing it in action is something else. Aparently an IMR would’t respond so violently to it rupturing.
Apparently this is a modded Convoy S2+. Would be great to put in 3x 219B. I see this being discussed in that thread overthere. Wondering how doable it is or if they are available somewhere with them installed at a decent price.
Only Richard from Mountain Electronics sells triple Convoys (with almost any led you wish for, and a great driver), but it is not cheap and shipping from the States spoils it even further!
Interesting, even if it is a tad expensive at $83 with my selected options. Seems it doesn’t use the original metal-only switch? Apparently the original switch is one aspect of the Convoy S2+ that is liked by many. Shipping to the Netherlands is $13.25 so that’s not too bad but it does bring the total to $97.07.
That’s a lot of money for a flashlight, especially compared to the regular S2+ with a 4C emitter which is only $17.20 plus and free shipping. And I still need to get batteries and a charger as well . But it’s good to know the option is available (although black is currently sold out).
I’ve built several triple Nichia 219c lights with Fet+1 drivers. None of them works on turbo with the protected batteries I have (Keeppower and NCR18650B). They rather cry for high-drain IMR cells.
So my limited experience suggests:
EITHER: you chose a regulated driver with reduced output (that’s visually not as dramatic as it sounds!)
OR: you go Fet and IMR for full triple output (there you will run into temperature issues!)
I suggest buying a S2+ in neutral white
And go from there
Add the short tube
Mod it into a triple
But just start with a NW Cree since it I very pleasant on the eyes.
(Personally I’d take a brighter NW over a Nichia and I compared them side by side.
But it is personal sobthe S2+ is a great platform for
easy mods (emitter swap, lenses to get rid of hotspot
Harder mods, triple LEDs
I can only say this in Dutch
Staar je niet blind on de Nichias
Test it
While reading and seeing all the pics I thought “yeah need those Nichia” ordered a bunch of 219b and one RMMs 219c
Put the 219c in a C8.
Nah didn’t do it for me so it is back to its original XML2 NW.
And check the Astrolux A01
The head is a bit bigger, but still small and it has nice knurling and in black ALU cheap.
