Freeme Review: JETBeam JET-1 MK 480lm XP-G2 14500/ AA - incomplete, pic only
51 posts / 0 new
freeme
freeme's picture
Last seen: 19 hours 25 min ago
Overview:
Brand: JetBeam
Model: JET-1
Price: $21.99 (for discount)
Emitter: CREE XP-G2 Cool White
Brightness: 480LM (manufacturer rated)
Mode: 3 Modes
Peak beam intensity: 4,200cd
Lens: Toughened Ultra-clear mineral glass with Anti-reflective Coating
Material: Aircraft grade aluminum alloy, military type III hard anodising
Mode Arrangement: Low, Mid, High
Mode Memory: Yes
Battery: 1*14500/ 1*AA
Net Weight: 16.7g (w/o battery)
Size: 19.5mm (head), 19mm (tail), 83mm (length)
Waterproof Standard: IPX-8 Standard Waterproof up to 2m
First Impression:
Close up look:
Weight:
User Interface:
Interesting Features:
Performance: Tailcap Amperage Readings
1) Tailcap measurement:
Low: mA
Mid: mA
High: A
Parasitic drain: --- μmA
Performance: Runtime
Beam Profile: Tint
Flashlights are projected to a sheet  of white acrylic at a distance of 15cm.
PWM (Pulse Wave Modulation):
PWM is pretty obivous in Low and Medium mode when you are using 14500 rechargeable battery.
Size Comparison:
JET-1 MK's color and finishing matched my favorite Niteye flashlights.
What I Like About JETBeam JET-1 MK:
  • Very attractive design. Typical JETBeam/ Niteye standard
  • Excellent machining and finishing.
  • Perfect EDC size.
  • Support both 14500 and AA batteries.
  • Good placement for logo, model, and serial number.
  • Threads are smooth to operate and well lube.
What Needs to Be Improved:
  • Lens fog up when light is turned on. Output level will be affected.
  • Slight tint shift to cool temperature when head turns warm on High.
  • JET-1 MK does not have a circular beam profile.
  • Although the threads are smooth, I suspect the threads are a bit loose.
  • Sample unit is slightly slanted when standing upright on tail.
  • Tapped screw hole has very limited usage. Most likely it is going to attract dust from your pocket.
Conclusion:
Coming soon
Our Rating
Power: ★★★✩✩
Easy of Mod: ★★★✩✩
Price: ★★★★✩
Overall value: ★★✩✩✩
Edited by: freeme on 07/19/2016 - 11:38
freeme
freeme's picture
Reserved for updates.
Noctiluco
Noctiluco's picture
Last seen: 3 hours 16 min ago
Ough! Not easy to mod? I was already imagining a 4000K light Sad
Thanks for the quick review
freeme
freeme's picture
I could see that there a little gap in here. I tried to open with my bare hands but it seem to be sealed.
Haha, nothing is un-modifiable for the experts. LED swap is still possible at this stage.
Noctiluco wrote:
Ough! Not easy to mod? I was already imagining a 4000K light Sad Thanks for the quick review
will34
will34's picture
Last seen: 2 weeks 17 hours ago
Nice review and pictures! I hope the bezel opens with a bit of heat and brute force, planning to swap for a XP-G3.
Is that fogging in your light because of moisture?
freeme
freeme's picture
Thank you. You will definitely need some help with the tools. Almost none of my lights exhibit such issue. I just left the light in my dry cabinet, will verify if it is due to moisture later.
will34 wrote:
Nice review and pictures! I hope the bezel opens with a bit of heat and brute force, planning to swap for a XP-G3. Is that fogging in your light because of moisture?
264
264's picture
Last seen: 1 week 6 days ago
Images are superb. You understand how to correctly light a scene. Thumbs Up Disappointed about the flashlight’s very cool tint. Looking forward to the rest of the review.
Noctiluco
Noctiluco's picture
I like dark-gray and smooth anodising typical of Jetbeam, nice that this little lights also show it; very good pictures freeme; I am again hopeful about a 4000K nice Jetbeams.
freeme
freeme's picture
Lens still turns foggy after leaving it in my dry cabinet over night. Doubt there is much I could do, unless I open up to find out the problem.
finges
Last seen: 1 day 13 hours ago
Nice pictures!
I also have the light on order and after seeing the tint in your pictures I definitly want to change the led and if possible the mcpcb to a copper one (just to have it in there Wink )
Can you do a runtime graph? Someting like that would be great http://i1024.photobucket.com/albums/y309/Budda_CPF/Manker%20E11/E11%20XX...
freeme
freeme's picture
Glad you like it. I will get the runtime chart up soon!
finges wrote:
Nice pictures! I also have the light on order and after seeing the tint in your pictures I definitly want to change the led and if possible the mcpcb to a copper one (just to have it in there Wink ) Can you do a runtime graph? Someting like that would be great
finges
Great!
lumenzilla
lumenzilla's picture
Last seen: 2 days 14 hours ago
Nice review!
I like its overall design, but IMO the head’s design is quite plain.
M4D M4X
M4D M4X's picture
Last seen: 38 min 52 sec ago
really great pictures!
thanks for the review
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
helloworld7
Last seen: 3 years 6 months ago
I wonder if that tapped screw hole that you mentioned can attach a jetbeam defense/window breaking cone. Thanks for the pics!
freeme
freeme's picture
Update:
finges
That is bad, how is pwm with a nimh?
freeme
freeme's picture
No visible PWM with AA.
quetzalcoatl
quetzalcoatl's picture
Last seen: 2 years 8 months ago
Thanks a lot for all the effort! I think that I´ll skip this one. Also it is a twisty… I don´t like AA twisties. Wink
giorgoskok
giorgoskok's picture
Last seen: 2 weeks 6 days ago
Still trying to unscrew the bezel …
Bc412
Got mine yesterday. I got like 500 lumen with my ceiling bounce with 14500. Pretty short runtime. Like 20 min and gets super hot.
Biggest disappointment is that it doesn’t pocket well. Pocket clip doesn’t hold in jeans tightly and the anno is very slick. Its been sliding around in my pocket all morning.
264
264's picture
I purchased three Jet mu, and two Jet-1-MK. One mu has a more neutral tint as well as one of the Jet-1-mk’s. I like all of them. Great price and very useful small lights. If I need a blinding wall of light I use my XinTD-SC 82-V5. If I need a very long run time my Thorfire VG10 fits the bill. Each flashlight is tailored to fit a niche. Smile
Ragsy
Ragsy's picture
Last seen: 12 hours 14 min ago
Nice review, thanks
I’m liking my Jet-I MK
I agree with Bc412 the clip is not much chop
I run mine on NIMH
G'day mate, ow ya garn?
Yeah, nah good mate
djburkes
djburkes's picture
Last seen: 2 years 1 month ago
Has anyone broken one of these lights down yet? I ordered one today, hopefully it’s not completely glued. I’d like to throw a fet in it.
giorgoskok
My jet-1 MK is glued between the pill amd the body .
But i think freeme said (not sure) , it has a removable bezel.
dhvl1357
Last seen: 3 weeks 3 days ago
Just received mine and I was shocked at the size of the xp-g2 (my first of this led). I was expecting an xp-g die size and quite the throw monster but have to say the beam resembles an xml2 in a larger reflectored light. Of course, it was my bad having the wrong expectations on this light, which is quite a steal for the money, truth be told.
Slow is smooth; smooth is fast.
hank
hank's picture
Last seen: 49 min 33 sec ago
So — moddable?
On sale: http://budgetlightforum.com/node/49312
somnambulism
Definitely moddable. Here’s one with a Nichia 219B:
It’s just that the bezel is glued in place on the head, so you need a strap wrench or some such to get it off.
pungo
Last seen: 9 months 2 weeks ago
I ordered one of these lights and now need recommendations for protected 14500 cells that will work with this flashlight. I read that some cells might fit too tight.
patmurris
patmurris's picture
Last seen: 1 day 2 hours ago
I’ve carried one for almost two month now and i’m very pleased with it so far.
I’m not a big fan of twisties but this one is smooth enough it can be operated one handed – although sometimes it skips modes if you are not twisting off far enough and get some sort of rebounce. I’m a bit sensitive to PWM but didn’t get annoyed with it yet. Must be relatively fast PWM?
It’s small and quite bright for the size with a 14500. I like the beam shape and decent throw too.
GB has it on sale these days… Just ordered a second one. Facepalm
Lexel
Lexel's picture
Last seen: 1 hour 47 min ago
I got 800mAh Keeppower cells
Last charge showed 848mAh
I opened it up for centering the LED and ordered a replacement XPL Hi
My advise for centering the reflector is to glue the reflector with the spacer, its almost impossible to get it centered without that, bcs it has not a typical centering ring
I ordered 3 of em only one got decent centered led
It is glued, but with some heat you can get it opened relatevily easy
Its like some soft acrylic glue
My Nitecore P12 is absolutely resistant to be opened up with more heat and way more force no chance
