Well done, i like that.
What a clever and delightful mod !
What amazes me about these little chargers is they don’t get warm/hot at all while charging. In contrast, my XtarWP2 is very warm all the time.
Why is that?
Sweet mod!
Added both to my shopping cart!
Great mod there.
Nice mod! the voltmeter fits perfect.
Any codes for the Nitecore SC2 charger?
Hi Martin
Any codes for a Thrunite TH20 headlamp?
Thanks
i asked
Nice and useful mod. Thanks for sharing.
new codes arrives for:
Nitecore CI6
CREE XP-G2 440LM Chameleon Series Tactical LED Flashlight
-> limited €U stock with great price!!!
Klarus ST15
CREE XP-L HI V3 1100LM Classic Tactical Setting LED Flashlight
af first a goodie:
astrolux | S3 (my Link) | ef5700 | $ 22.75 | PRICEDROP |
finally on stock :)
Lumintop SD4A 1000LM LED Flashlight
CREE XM-L2(U2) OR CREE XP-L HI
great deal – ask for details
Product name: | LUMINTOP SD4A CREE XM-L2(U2) And CREE XP-L HI LED Flashlight |
Total Emitters: | 1 |
Emitter Brand | CREE |
Emitter Type: | CREE XM-L2(U2) / CREE XP-L HI |
Max Lumens: | SD4A-XML:1000LM SD4A-XPL: 920LM |
Intensity: | SD4A-XML:20300cd SD4A-XPL: 40000cd |
Peak Beam Intensity: | SD4A-XML:285m SD4A-XPL: 400m |
Mode: | 8 Modes(Low-Mid-High-Turbo-Moonlight-Aviation Signal-SOS-Strobe) |
Max Runtime: | 51h |
Battery Configurations: | 4 X AA or 1X D Cell |
Switch Type: | Clicky |
Switch Location: | Side |
Working Voltage: | 0.9v-6.4v |
Impact Resistant | 1.5m |
Waterproof: | IPX-8 |
Weight: | 178g(without battery) |
Size: | 112mm(L)x41mm(Head)x41mm(Body) |
Nice price on the S3!
Any code for imalent DN11?
there will be :)
Is the Astrolux S3 made by Manker? If so, presumably it won’t be available for much longer?
you may be right....
new Astrolux MH10!
presale start soon... ;)
Features:
1. Built-in temperature control module, automatically adjust the brightness according to ambient temperature working status of each output in order to achieve
the best working condition
2. Tip overheated housing
In the lighting state case temperature reaches 55 degrees, LCD display will flash rapidly to alert temperature symbol with dimming to ensure the user's comfort,
so as to prevent excessive heat generated by the discomfort.
3. Low battery indicator
when the battery voltage is lower than 3.1V, LCD will display (the frequency of 30 times per sencond), battery symbol flashes to prompt the user to replace the
battery or charge it in time.
4. Aerospace grade aluminum, Army regulations three hardened wear-resistant surface treatment
Which company is behind this ?
Thanks , i missed this thread .
