Going back to the Lumens query as well, I have other torches that are a genuine 220 and 270 lumens and makes you realise the quoted 300 lumens for a SK 68 (whilst they’re brilliant little torches) is totally exaggerated …… does anyone happen to know if the quoted numbers for this may possibly be realistic …… especially for the mid 250 lms
In your SK68, did you use a 14500 battery, or an AA? I’m not sure if the 300 lumens for the SK68 is legitimate or exaggerated. It could be legitimate if it meant running on a 14500, and it meant the amount of lumens coming off the LED itself, not the lumens coming out of the front. And if it referred to a Cree LED, not a Lattice Bright LED.
I don’t have an answer to your original lumens question, since I currently don’t have the i3.
Yes am using a 14500 but if you put it next to a Led Lenser T7.2 which is 220 lumen the Lenser is massively brighter … a very noticeable difference so the SK 68 whilst it’s a great little pocket torch the power’s hugely over estimated.
Mine arrived today … 620 lm … or don’t they understand where the decimal point goes …… 62 lm … if you carry a handbag and want something “convenient” to put in it great but anything else seriously save your money.
What battery where you using? And did you take any tailcap amp readings? They will tell you a lot on how many lumens it might be making.
Also, this is a floody LED. So will not throw very well, be it a zoomy or reflector light of this size. Assuming you go the XM-L2 version, or did you go for the XP-G2?
The light looks rather mod friendly. A driver swap will make it much more powerful.
It is indeed mod-friendly, xref to the what did you mod today thread 2 weeks ago:
I had the XP-G2 version, and on a 16340 Efest IMR, the high setting was certainly not 62 lumen, I did not measure it before modding but it could well be over 400 lumen. The tailboard can be swapped by the standard board+small Omten switch, if one prefers that.
Yesterday I used my i3 as a bike light and it went through a short but heavy rain storm (me too ). I can hereby report that, as expected from the design, the i3 is not rainproof, afterwards the lens was fully condensed on the inside. The light did not fail or anything, after running 10 minutes on high with lens off it was good to go again.
Pity to hear that it’s not rainproof, that’s a negative.
How hard is it to get the lens off? I see the notches in the bezel, presumably for twisting?
I found the hidden strobe (3 fast clicks) from any brightness level
— for my use, that is a nice feature. Means it can be a daily carry for pedestrian crossing use.
Comes with a little charger (AC 2-conductor cord, plug socket, and mini-USB socket)
Power and Charge LEDs
Back is labeled
with a patent number
Li-ion: 18650, 17670, 18490, 14500, 16340, 10440
100-240v, 50/60Hz, DC 5V 1A
Output 4.2v plus or minus 1% 0.6A
TEL: 400-670-1003
WEB: www.zlsh.net
Power light is blue, and charge light is blue with no cell, dim red with a cell charging,
Box included a 16340 cell, OTR brand, yellow shrinkwrap, labeled 700 mAh, 2.6 Wh
Not fully charged when shipped (this is good)
2 extra O-rings in a plastic bag, and a slightly stretchy lanyard.
Very cushiony little carrying bag with drawstring
Looking at the shipping label, it says
Return Department
2070 Global Way Ste B
Hebron, KY 41048 That’s a big, big plus if there’s ever a problem, to be able to send it to Kentucky
(It came USPS First Class, International Bridge)
Hm, I’ll try charging the cell and see what the charged resting voltage is.
Charger looks glued together.
