Jaxman Z1 Discussion
286 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 1 min 52 sec ago
They now show sold out anyway. Wink
The Miller
The Miller's picture
hmm works hee and on mobile too
http://www.cnqualitygoods.com/
then click other brands
WolfA
WolfA's picture
Last seen: 10 months 2 days ago
DB Custom wrote:
WolfA, can you do a resistor mod and bump that current? The XHP-50 runs really well at twice that current draw, even 3.5-4A would be a significant improvement. If you do get secondary pills, an FET driver to an XM-L2 de-domed is probably about the maximum output as far as spot intensity goes. A Zener modded FET to an MT-G2 should also be pretty rewarding, but in a different way entirely. Wink
Hi Dale,
Your suggestions are very welcome and meet my plans of having 3 different pills! My problem is I’m not sure which resistor I should bridge. I identified 2 possible candidates sitting side by side one R250 the other R260, not connected at the life side, but don’t really know!
I’ll take a picture as soon there is time…. Really busy the next three days!
"A black bulb which, when switched on, turns the room dark"
(Gyro Gearloose)
Hoop
Hoop's picture
Last seen: 22 sec ago
hank wrote:
Ask Hoop how he gets his copper pill inside surfaces flat. You can see slight variation in the mirror surface but can’t feel any irregularity nor detect any unevenness with a small straightedge.
I make my pills on a CNC milling machining center. A sharp endmill finishes the pocket with a light finishing pass. This of course leaves visible tooling “marks” but they are not able to be felt with a fingernail. It’s very flat.
Looks to me like the Z1 could use some copper lovin? Big Smile
hank
hank's picture
Last seen: 1 hour 46 min ago
> Photos can be enhanced to emphasise tooling marks.
But you’re not accusing anyone of doing that.
bella-headlight
Last seen: 1 month 1 week ago
Sharpie wrote:
The Miller wrote:
hmm works hee and on mobile too http://www.cnqualitygoods.com/ then click other brands
Price of everything, value of nothing ?
PS: your links don’t work.
Please tell us about your’s if/when it arrives.
www.cnqualitygoods.com ? Well, good luck.
The Millers link works fine for me Thumbs Up
Ian
hank
hank's picture
Please don’t confuse me with whoever it is you’re arguing with.
I mentioned the fingernail as a way of checking what we think we see, by touching the surface to determine whether there’s any roughness that can be felt.
The Miller
Yeah I don’t get why people have trouble with it, the first link to the Jax works also on my phone but the main link kicks me to a mobile site that has no functionality.
On PC all work
“Price of everything, value of nothing ?”
I don’t get this question, what do you mean?
Got an email that it is send out.
And of course tell all about it when it comes
Big surprise because when I ordered it they said clearly out of stock.
For now I got
A good price
Fast email of shipment
So all aspects I could encounter are very good.
So we’ll see how the rest goes Wink
DB Custom
DB Custom's picture
Hoop nailed it, the Z1 benefits from a nice copper pill. So Hoop, when will they be ready? Big Smile
It seemed to me that if I was doing this, there was no need to piggyback the 17mm driver onto the original Jaxman board. So I made the pill to fit the driver. Now even the weaker MNKE cell pulls 15.55, almost scared to test an Efest. Wink
I’m certainly no pro machinist, and some time off makes me even rustier. But all in all it worked out pretty well. Had to use what was available so a good bit of time was spent reducing an oversize bar of Tellurium Cu, and then I had issues fitting the new brass retaining ring into the small pocket, probably a lack of the proper tools, but I persevered and it worked out pretty well. Big Smile
The Miller
Oh man you just made that?
it is a shame the underscore makes thngs italic since this screams for a smiley that cannot be shown O
let me google it
YES this is what I want to show or
Sharpie
Last seen: 3 years 7 months ago
That looks beautiful.
It will be interesting to know what thermal improvement results.
TBH, all my engineering knowledge tells me that a decent aluminium alloy pill should also outperform anything made of brass.
Whereas Al vs Cu is a trickier one. Thermal conduction, thermal mass, weight, cost, ease of machining, and doubtless other factors, all need consideration and trad-off.
I suppose, the bottom line, is the price and availability, compared with $5 for the standard brass pill, and what true benefits will be gained, and whether it will make any practical difference, except in extreme modifications.
How much would you estimate that your copper pill should cost, as a commercial proposition ?
“J Team” member
DB Custom
DB Custom's picture
Happy Birthday America! Big Smile
DB Custom
DB Custom's picture
Sharpie, the cost is probably 3-4 times higher, Hoop can probably make the pills for around $15-18. In normal scenario’s this is probably unwarranted, but this Luminus SBT-70 is not efficient and burns a LOT of current as heat, so it’s necessary here to go the extra mile.
18.75A seems to be about the peak here on an Efest 4200mAh cell. At the 43 second step down point with this particular driver, it’s just about burning my hand, copper or no copper.
MG
Happy 4th to you, Dale and the Gang!
Nice pictures!
Sharpie
That makes sense, you do like to push things “to infinity, and beyond”.
It looks like a big chunk, how many grams ?
“J Team” member
DB Custom
DB Custom's picture
The brass pill, built, weighs 43 grams. The copper pill, built, weighs 68 grams.
Sharpie
hank wrote:
Please don’t confuse me with whoever it is you’re arguing with. I mentioned the fingernail as a way of checking what we think we see, by touching the surface to determine whether there’s any roughness that can be felt.
Sorry, I must have missed that post.
Hoop mentioned the fingernail test. I don’t recall that you did.
It is a standard test, and not about whether “there’s any roughness that can be felt”.
That would set a ridiculously stringent test.
By comparison with a calibrated set of samples, the fingernail can be a remarkably precise way to compare surface finish.
And is accepted as such.
To not feel any roughness would require an almost mirror finish.
“J Team” member
DB Custom
DB Custom's picture
We have people here that take the shelf to a mirror finish. I personally don’t like to as it prohibits the Arctic Alumina Thermal Adhesive from adhering to the slick surface and can allow the mcpcb to shift once heated. It is certainly easier to remove a glued mcpcb from a mirror polished shelf.
So I tend to focus more on how flat it is and not worry much about some slight surface imperfections. I REALLY don’t like a dimple directly under the emitter from a pre-drill situation being plunged too deeply.
DB Custom
DB Custom's picture
Miller, I appreciate it but really I’m just a hack still. I can manage to make something that works, Hoop can make it look like Art. Wink
Sharpie
I think you already have nearly 60% more thermal mass. Copper and Brass are much the same, per gram. I’ll do an estimate c.f. Aluminium tomorrow.
PS: Aluminium has by far the best specific heat of any metal. Over twice that of copper. But being so much less dense, it takes a much larger volume of it.
Plain old water of course, is more than four times better, and if allowed to change phase (into steam) vastly more so.
Steampunk extreme torches ?
“J Team” member
DB Custom
DB Custom's picture
With the exception of Magnesium and of course Beryllium, yes Aluminum is up there pretty high. But like Magnesium, the weight or mass is so low that it’s disproportionate for real world usage in many cases. Made the same size, copper blows the doors off virtually anything else commonly available. I did some testing concerning this a couple of years ago with the Trinity in C8’s, once the copper was brought into the picture prolonged high output and run time (output at life of cell) really showed the difference.
Water will come to play in a handheld flashlight, sure enough, it’s just a matter of time. Pretty sure Bucket already did that, some time back. But it’ll happen as we continue to see improvements in LED’s and the power supplies that run em.
Sharpie
Yes, you got me there.
Practical magnesium alloys , not much difference.
Beryllium, well, yes. But the toxicity, and expense.
That’s why it even was banned from Formula One.
But until then, was the thing for brake callipers, for those who could afford it, and handle it safely.
Nevermind inside the engine, e.g.
http://www.f1fanatic.co.uk/2007/02/08/banned-beryllium/
“J Team” member
Hoop
Hoop's picture
Hank is sending me his Z1 so I’ll get some pills worked out pretty soon. Big Smile I’ll be sending it back with a copper pill in it.
The tooling marks visible in photographs of my pills probably give the impression of a rough surface, so I mentioned the fingernail test just to say that you can’t feel any roughness even though you can see distinct tooling marks because of how they interact with light. As for what is really necessary for production standards, I’d say just flat and fairly smooth. A normal finish facing pass with a decent insert should accomplish this in a matter of seconds on a lathe, but that seems out of reach for a lot of manufacturers. Sick
Kenjii
Kenjii's picture
Last seen: 1 year 1 week ago
Hi,
I used an 17-20mm Adapter for the LD-1 driver instead of piggypack it which fits perfect in my Z1.
http://www.mtnelectronics.com/index.php?route=product/product&path=25_72...
But a little extra weight with copper is welcome Wink
Regards
Kenjii
teacher
teacher's picture
I have a question about tooling marks, or even slight minute tooling ridges that one could actually feel with a fingernail in the MCPCB pocket of the pill. ( I am not talking about super grossly rough tooling marks mind you ).
If it they were flat, would the slightly rough tooling ridges along with a proper amount of Arctic Silver 5 Premium not give better heat transfer from the MCPBC to the pill than if it were smooth.
My though is the slight tooling ridges would indeed give more surface area for the heat to be transferred from the MCPCB to the pill, by way of the Arctic Silver 5 Premium of course. That is my theory anyway, same as cooling fins on the outside of the light dissipates much more heat than a smooth surface with no fins.
Yeah, the super smooth and polished pockets on the pills look very nice indeed… I agree with that. But, they also have less surface area to transfer the heat to than a pocket with slight tooling ridges.
Just my thoughts…….
The Miller
No
Article silver is purely for filling tiny gaps.
The smoother the better since less paste is needed.
WolfA
WolfA's picture
Hi, I did the resistor mod on the stock Z1 XHP50! As I only had a R100 at hand this was added to the original R150, giving a total of 0.06 Ohm instead of 0.15 Ohm on high.
Tailcap readings BEFORE:
L:0.05A M:0.5A H:2.5A
Tailcap readings AFTER:
L:0.05A M: 0.5A H:5A
I shaved the XHP50 at the same time so I can only say it got a significantly brighter projection Smile
(Gyro Gearloose)
DB Custom
DB Custom's picture
Thermal paste is nowhere near as effective as a good metal to metal contact.
There are some adhesion losses with a mirror finish, but this usually doesn’t mean a lot to us inside a flashlight. For a light like the Z1 there is a cover plate that holds the emitter/mcpcb down so it’s not likely to move even if dropped or hard use EDC.
The key to a paste at optimum efficiency is filling microscopic differences, eliminating air. I tend to use the microprocessor instructions and apply a small ball of paste in the center, then lay the mcpcb on top and press it so that the paste spreads out. The trick here is to use enough without using too much, but even if too much is applied a good bit of pressure can push it out and the excess removed. Too little and there are air gaps around the periphery of the mcpcb.
Some small tooling ridges from a fast feed aren’t particularly of issue, as long as the surface is flat and true… true being important so the emitter faces the optic as perfectly as possible. What has to be weighed is the ability to reduce these marks while maintaining a flat true surface, it’s all too easy to mess up the paradigm while trying to improve surface contact, trading one issue for a more serious flaw.
teacher
teacher's picture
The Miller wrote:
No
Maybe maybe not. Tiny gaps are what I am referring to.
Does this stuff, Arctic Silver 5 Premium; actually transfer heat or not? I think it does… but how good does it? That I do not know yet, but I shall find out by calling them right now. Thumbs Up
EDIT: / Just called them they are closed for facility maintenance this week reopen 11 July 2016.
DB Custom
DB Custom's picture
The Liquid Pro made with Gallium is a metal that’s liquid at room temp and hardens or solidifies at higher temps, might go that route if you have copper to brass, it’ll eat aluminum though.
