FWIW, Ferrero Rocher is supposed to blink once and shut off when power is connected. Short and long presses should go through the modes in opposite directions. However, it also tries to use two pins for battery indicator LEDs, and that could be messing with the behavior.
I suspect that what happens is a short or long press cycles normally until you let go, then it tries to indicate battery status by turning on one or two pins. This causes the light to turn on another power channel at 100%, and it drowns out any mode changes you do afterward.
If you disable the battery indicator code, it’ll probably behave a bit better. But this at least suggests that the e-switch pin is physically working.
Anyone know? I didn’t think it needed the zener if using with one cell. But I see that the new blf fet+1 includes a zener even when used with one cell. So IDK?
Well I build my first driver for good or for worst… Now I’m trying to sort through bistro triple down so I can flash it to this driver. This is the version optimized for two less, but I’m going to use all three channels on one xpl hi.
Pilotdog68, under the 7135 on the top of the board is the trace that can be cut to separate the 7135s on the back from the fet on the front. The trace is small, would that small trace carry the current ok? It’s probably common, but I never thought about how much current goes through these traces til now.
Ahh man… This is hard! I have so many questions :confounded:
I just realized I need to change the pin layout in tks bistro tripledown firmware. The layouts between board versions are a bit different. Do I just start changing pin labels in the attiny.h file?
You would probably need to change a few lines in tk-attiny.h in the section about “TRIPLEDOWN_LAYOUT”.
It may help to have the attiny reference manual open, to see which pins have which internal names.
Also note that the PWM on pins 5/6 works a bit differently than on pins 2/3, so you may also need to edit the first page of main() if you move any parts from one of those groups to the other.
So… In the attiny.h file do I need to mess with the output compare register if I change the pins? All three pins need changing. FET is on pin6, 8x7135s on pin5, and 1x7135 is on pin3.
And also, In the .c file, do I need to mess with the PWM counter in some way?
Let’s see… I think you can just rotate the assignment of names to values like this…
#define PWM_PIN PB0 // pin 5, 6x7135 PWM
#define PWM_LVL OCR0A // OCR0B is the output compare register for PB0
#define ALT_PWM_PIN PB4 // pin 3, 1x7135 PWM
#define ALT_PWM_LVL OCR1B // OCR0A is the output compare register for PB4
#define FET_PWM_PIN PB1 // pin 6
#define FET_PWM_LVL OCR0B // output compare register for PB1
… and then I think it should work. But with 1x7135 on pin 3 (second PWM counter), your moon mode is probably going to suck. IIRC, that channel is locked at 31 kHz but moon usually needs to be significantly slower than that. If the lowest PWM level is too low, you’ll need to recalculate the ramps. And the lowest levels will probably still be more voltage-sensitive due to the short pulse time.
