Manker E14 Mods
Very nice.
Did you double up the rear spring by adding the front spring? I assume this is equivalent to a bypass.
I was lucky; no glue on mine.
Bob
Interesting! Can you provide a link to what you use? I can see a number of uses for this in my mods.
How about a compromise :wink:
Thread updated with new stuff about the head rebuilding and i think i’ve answered those who asked questions there.
Thanks for reading.
Pimp master.
Wow CRX. the black in the heatsink slots looks great! :slight_smile: :beer:
Hmm… after seeing the innards of yours I’m inclined to follow suit and do some tweaking. Nice looking head, too. Did you rub off the coating and will it patina now?
Thanks for posting this up :slight_smile:
Thanks for posting this very nice pictorial of the build and tweaks!
Is this copper?
Please, I need confirmation.
my S41 is glued so i can’t open it without damaging the head :person_facepalming:
It looks like we are looking at nickel. All Noctigons are very thin coated gold on the outside, nickel underneath to help the with the gold bonding, and then the solid copper under the nickel. Around the indentations, you can see all 3 layers.
The gold can be removed practically waving super fine grit sandpaper over it, while the nickel takes a little bit of rubbing. I've sanded down many a Noctigons over the years.
Thanks! It seemed aluminum.
X2
Looks awesome.
Bob
Q: is the bluing conductive, and can it be soldered to?
great job
thanks for your time to document it and share with us
btw your collection looks great
Great thread crx! that looks stunning with the black stripes.
Great job, it looks super.
CRX, what battery are you using? It must be 16340 or cr123? I just took about .005” off of each end of the battery tube to square it up and improve contact. I don’t think I can go any shorter and still take a 18350. Also mine is a S41 but I doubt there’s any difference.
V2 looks georgous!
Yes the coating came off mostly with acetone, should patina nicely now
Yeah i think Toms explanation is right there
C’mon, give it a shot like i showed, you can do it :wink:
It’s just a thin layer of oxidised copper so would imagine it’s only slighly less conductive and would need cleaned before soldering
Thanks :slight_smile:
Yeah i think it does look better now
That’s why i trimmed down the driver retaining ring and replaced the spring with a copper stud so as to leave plenty of space in the battery compartment.
Here’s mine with a flat top purple Efest 18350, still space for a button top
V2, i like that
Amazing work!!! What’s your address, I want to send you mine :slight_smile:
(joking…kinda….not really)
