looks great this small light pity that it has no memory for gesture turn on off and it always turns of in high mode
the elliptical tir lens with xp-l led would be great stuff but if it always turns on on high by gesture you have to press the bottum with oily hands to dimm it down which is not ideal
When in sensor (gesture) mode there is no dimming of the light. The next touching of the switch turns it off if it’s on and takes it out of sensor mode. If it’s off while in sensor mode pushing the switch takes it out of sensor mode and leaves the light off.
I got mine yesterday. I charged 2 batteries in it and both came off at 4.18 volts. The current draw went from .5A to 0.05A when charging but I have no way of monitoring what the voltage was.
I will give it a go this weekend
I think the first thing is to remove the plastic tube inside then the rest can slide out
This lamp have much more potential then the stock lamp and it’s not bright enought for my liking.
I got 2 of this one works one has strange issues I open it up and there you can see the driver and led it’s easy to mod but I got no oder what parts wrong in mine and what parts could be changed to better ones to get more lumens. I guess just the led alone won’t make a big difference
I honestly can’t figure it out from the posts. Please can anyone tell me how the LED is hsatsinked? Is there anything behind the pcb when installed in the light? Thanks
I received mine…and i can say the output is really nice, i think a headlight can be max 300lumens…going higher can only decrease runtime, and here there is only space for 1 battery…not 2 or 3 in parallel.
I think for this little price this is THE HEADLIGHT. Microusb charged well it…voltage perfectly 4.19v
I ordered and just received two of these lights. Of course now that I have them, I see that GearBest has them on sale for $8.99.
Since I also recently received some XP-G emitters, would these be an upgrade to the noname emitter in the light? I’m not looking for huge output, but if the XP-G is more efficient, the battery will last longer while working or hiking.
