I think this thread title and original post is rather harsh and unjustified.
I’ve just reviewed this light, and it is generally positive review - Review: Klarus Mi7 (1xAA/14500)
As with all flashlights, it may not suit everyone, but it is likely to be one of 2016’s most popular lights.
How is my post unjustified? My Klaris isn’t bright compared to lower output flashlights I own. You would think that having a smaller hotspot than my first gen SC52, and my S1, the beam would be more intense than those two. It was just the opposite. I ended up giving it away to another BLF member. He’ll have it on Monday. Let’s see what he thinks.
Well, having a thread title saying “avoid” is a bit over the top. You should hope that Klarus don’t have good lawyers, as this thread is quite high up the google search rankings for this light!
Just because a light doesn’t meet your personal needs, or is not as good at some things as other lights in it’s category, doesn’t justify an “avoid” in the thread title. Based on many posts on here and CPF, there seem to be a lot of people that do like this light! Yes, the claimed output is rather optimistic, but for it’s medium price point this is a pretty impressive light. You are comparing against lights with 25-50% higher price !
I just got mine this morning. Not as pink as I feared. In comparison to my E11 and Jetbeam AA it holds its own very well, or at least perceptively so. Will do proper measurements later on.
Yeah but Klarus is claiming 700 lumens, while to 2 lights I compared it to are 500 lumens and are noticeably brighter . I purchased it based on it’s claimed lumen output alone. IMO, it’s a huge disappointment.
I think you got a lemon because not as bright as 500 lumen lights would mean 400 lumen or so. The Mi7 should have about 550-600 lumen according to many other tests here.
Very possible. I can only go by the one I recieved . It seems to work nomally. No flicker, modes work normally, etc. My 14500’s work perfectly fine. What else can I say?
2 reviewers have measured the light at over 600 lumens. It should be brighter than your 500 lumen lights unless you got a lemon.
Also it still sounds like you’re comparing brightness by looking at the hotspots. This is NOT how to do it. You need to point the light at the ceiling and look at the reflected light at the floor… or use an integrating sphere. Hotspots alone can be very misleading. For instance, the Klarus might have a smaller dimmer hotspot and yet still be brighter than your 500 lumen lights due to wider spill. If you’re trying to measure total lumens produced by a light you cannot look directly at the hotspots.
It’s also possible you got a lemon. My recollection is that even with the same brightness bin there’s a +–20% brightness range. It’s possible your Klarus just happens to be at the bottom of that range while your 500 lumen lights are at the top.
A third possibility could be your cells aren’t high enough quality or are too old to get maximum output. I don’t have this light myself, but my favorite 14500 cell is the Efest purple IMR from Mountain Electronics. With one of those in my modded 1xXPL HI Skilhunt DS16 with FET driver and my light is as bright as my SC600w III HI. So well over 1100 lumens for a brief period of time.
The Op says it’s not kickin out the light it should. I tend to trust folks on this forum and Klarus tends to overstate lumens anyways. The g30 puts out 1900 from a claimed 2450. I agree, wait til folks get the G20, there’s gonna be a s$&tstorm!!
Look guys, I’m not a newbie with flashlights. I have around 50 over the course of the last 5 years and never been more disappointed. I don’t care what ceiling bounce might say, I go with what my eye says. And it say’s this thing sucks. It’s true my particular Mi7 could be on the lower end of the scale when it comes to output. But that’s how I’m judging it. That being said, I’m not a happy camper. That’s all I can say. Buy one at your own risk.
Glenn
Edit: someone marked this post as rude? Who ever it is, get a freaking life!
I guess nobody has an accurate sphere here but you can take other lights to compare with from the home made sphere. For the GB price this is probably the cheapest and brightest AA light you can get. Is there even a brighter 1xAA light? I mean we are talking about a keychainlight price and it even offers lock out and battery checker. Even with 550-600 lumens it makes sense to buy it.
Ok, but i guess not much more and that thing was designed for unprotected high drain 14500IMR batteries, its also much thicker and more expensive. The Klarus is for normal protected 14500 batteries. The nitecore is also much dimmer when using eneloops compared to the Mi7.
Actually I think it’s a defect only present in some EA11 samples. I saw people reporting the same problem on CPF. Some had the problem some did not. Also my EC11 and EA21 do not have the problem.
