Disappointed with my Klarus Mi7
2 reviewers have measured the light at over 600 lumens. It should be brighter than your 500 lumen lights unless you got a lemon.
Also it still sounds like you’re comparing brightness by looking at the hotspots. This is NOT how to do it. You need to point the light at the ceiling and look at the reflected light at the floor… or use an integrating sphere. Hotspots alone can be very misleading. For instance, the Klarus might have a smaller dimmer hotspot and yet still be brighter than your 500 lumen lights due to wider spill. If you’re trying to measure total lumens produced by a light you cannot look directly at the hotspots.
It’s also possible you got a lemon. My recollection is that even with the same brightness bin there’s a +–20% brightness range. It’s possible your Klarus just happens to be at the bottom of that range while your 500 lumen lights are at the top.
A third possibility could be your cells aren’t high enough quality or are too old to get maximum output. I don’t have this light myself, but my favorite 14500 cell is the Efest purple IMR from Mountain Electronics. With one of those in my modded 1xXPL HI Skilhunt DS16 with FET driver and my light is as bright as my SC600w III HI. So well over 1100 lumens for a brief period of time.
So who here has tested it with an accurate sphere? Anybody?
The Op says it’s not kickin out the light it should. I tend to trust folks on this forum and Klarus tends to overstate lumens anyways. The g30 puts out 1900 from a claimed 2450. I agree, wait til folks get the G20, there’s gonna be a s$&tstorm!!
Look guys, I’m not a newbie with flashlights. I have around 50 over the course of the last 5 years and never been more disappointed. I don’t care what ceiling bounce might say, I go with what my eye says. And it say’s this thing sucks. It’s true my particular Mi7 could be on the lower end of the scale when it comes to output. But that’s how I’m judging it. That being said, I’m not a happy camper. That’s all I can say. Buy one at your own risk.
Glenn
Edit: someone marked this post as rude? Who ever it is, get a freaking life!
I guess nobody has an accurate sphere here but you can take other lights to compare with from the home made sphere. For the GB price this is probably the cheapest and brightest AA light you can get. Is there even a brighter 1xAA light? I mean we are talking about a keychainlight price and it even offers lock out and battery checker. Even with 550-600 lumens it makes sense to buy it.
Since you ask, Yes there is. Nitecore EA11 for one.
Ok, but i guess not much more and that thing was designed for unprotected high drain 14500IMR batteries, its also much thicker and more expensive. The Klarus is for normal protected 14500 batteries. The nitecore is also much dimmer when using eneloops compared to the Mi7.
Be warned that the EA11 also has very large parasitic drain.
Mine drained a full IMR 14500 to 0 volts after just 2 weeks of non-use. Definitely use tailcap lockout if not planning on using it within 24 hours.
May be your Nitecore EA11 has large parasitic drain, but my 2 Nitecore EA11 lights do not.
Actually I think it’s a defect only present in some EA11 samples. I saw people reporting the same problem on CPF. Some had the problem some did not. Also my EC11 and EA21 do not have the problem.
Great, I was hoping that somebody would make a comparison between Manker E11 and Klarus Mi7.
Looking forward to this and thanks!
K.
Subscribed
* [quote=atbglenn] Look guys, I'm not a newbie with flashlights. I have around 50 over the course of the last 5 years and never been more disappointed. I don't care what ceiling bounce might say, I go with what my eye says. And it say's this thing sucks. It's true my particular Mi7 could be on the lower end of the scale when it comes to output. But that's how I'm judging it. That being said, I'm not a happy camper. That's all I can say. Buy one at your own risk. Glenn*
I received the Mi7 from atbglenn over a week ago. I have to concur with him. The light is putting out maybe 300-350 lumens at best on AA/NIMH/or 14500. I Dont believe it recognizes a 14500 battery. IT IS DEFECTIVE. I contacted BangGood and after 3 back and forths, instead of replacement they want a Video. They have the original order # and understand that the light was sent from him to me, yet seem to doubt the word of two fairly experienced flashlight people from a reputable flashlight forum. Both of us have been around going on 5 years. However BanGgood resolves this is up to them. I refuse to make a video of a defective light. It would take an integrating sphere to get them to believe us. So Banggood, do as you see fit. I don't know how I could better convey to you that this is a defective light. The OP deserves a replacement.
How about amp readings as proof?
[quote=Streamer]
[/quote]
[quote=Streamer]
is not neccesary a sphere. I think with a luxmeter will be enough for see if there are the same output on the center of the beam with NimH and with 14500…
Point is, I’m tired of Banggood assuming people are stupid. To the general public, maybe that is the case. But on BLF, most of us are in the know.
Send out a light that is proclaimed to be puttin out a conservative 550 lumens is one thing. But 300-350 is UN-Acceptable Yes, 14500 yields maybe @ one hundred more lux than NIMH…but the total outut is still @300-350 lumens. This sample Mi7 is clearly a DUD… I don’t need the hassle of assembling a film crew to produce a video to prove that. It’s the principle of Banggood doubting buyers reports. Especially since this is BLF forum and the OP and I have been around going on 5 years now.
ETA: I won’t be commenting any more on this as it’s a souring experience. Through 4 exchanges, the ball is now in BG’s court. Some of you may say I’m not playing by their rules by not sending a video. If that’s the case, read the first paragraph above again
Let them do as they may.
Banggood is a store. They request a proof for not normal functioning…of course is a is a hassle, but is necessary.
Not every body is a good person and many people try to take advantage, they can not trust (of course I’m not talking about you, I do not know you). And the time it takes one on a forum is not a sign of anything. We must be realistic and not get angry …
Said I wouldn’t comment but forgot one piece of critical evidence. It’s the smokin’ gun.
The light does not step down…ever. That’s coz it never is in turbo mode. DEFECT
Thanks for listening.
So, the brillliant people at Banggood have read this thread and continue to Dodge, Duck, & Hide from admitting the light is defective… They do everything in their power to NOT REPLACE IT or admit that it IS defective. Here below is their latest 2 replies in private Email .
Dear Sir:
We are sorry for the inconvenience and* I am the professional guy*.For the defective flashlight can you please send us a video to show the working conditon?If you had reported the problem on the BLF forum then please send us the right link of the post.
After checking we could solve the problem for you.
best regards
Alysonhe
A professional guy…really?
So I sent them the link to this thread…And the PROFESSIONAL guy read it….and this is their ridiculous reply.
Dear Sir:
Thank you for your information and I checked it.For the problem did you meant that the lumens was not so bright as in the specification?Did you checked if the flashlight modes working normal?According to the other customers posts it seems that you need to change to other AA or 14500 battery for it.
Hope to hear from you.
best regards
Alysonhe
Really? So they can’t read OR just playing stupid to STALL? So you see they are just trying to put it off and grow some whiskers so the issue will go away. Piss Poor business pracitice. They get a lot of stuff right, but they sure back up to cover their butts when something goes wrong.
Dont’ really give a dam what they do. But they are not going to deny that it is a defective product and tell me I need to STICK other batteries in it. Banggood is showing their true colors when it comes to backing what they sell.
At this point, I think the PROFESSIONAL GUY is merely a bouncer. Someone to act dumb and chase the problem away, so they can keep YOUR ca$h. Pitiful.
Not sure if they’re playing dumb or can’t understand you well enough, I can only advise you to follow their “game” and say yes I tried to all of their questions. Eventually they will have to do something, if not then PayPal is the last resort.
To be fair, imagine you were bangood and on a daily basis you receive tons of claims but at the end 50% are just users fault, so they have to assume every consumer is stupid, add the language barrier to that and this is the result…
