Wow! 68 reads and only one comment! Either I must write the worst reviews and take the worst pictures ever or Chicago X and I are the only ones who like this light. LOL! ;)
If it's me then suck it up people, I'm going to make more reviews anyway.
Count me in. :D
Nice review and nice light! Didn't realize how small it was, makes me wish I'd have ordered one.
Preliminary numbers with a cheap and nasty RCR123.
Light | Battery |
Gas can High | RCR123 |
Med | RCR123 |
Low | RCR123 |
Nice review but it's still under powered.
Thanks for the review , Johnny Mac .
Nice job on the lanyard .
Not if you want an hour of runtime....
Great review. Can't wait for mine. Don't have any 16340's (damn). Anyone recommend a good battery?
Trustfire flames work for most folks. But there are fake ones out there. I've not heard any complaints about the ones DX sells.
These work for me but mine have a relatively low cutoff current on the protection circuit. This is an issue with the Ultrafire RL-118 but I use IMR cells in it.
If these fit you'll get a bit more runtime. I don't have any of those but will try putting an 18650 version in to see if the tube has enough diameter to take the width - which I doubt.
It doesn't. Even a 17mm cell won't fit, I tried a 17670 to see. Some of the fatter protected 16340's might not fit.
Might have to try the Flames
That's why you get Med and Low
And nice work with the lanyard. Maybe I should try the same.
Thanks, guys! I like it too...clean, simple and elegant. I wish more lights had lanyard holes that would allow this type of lanyard. I did it on this one to keep metal on metal scratches in the finish from occurring due to split rings or snap hooks.
It tempted me a lot, but I have now three different Lithium batteries and I did not want to get an extra one.
Very good review, and very good loonking flashlight and finishes.
I believe underdriven is under what the manufacturer states as the maximum recomended, I find your answer a bit tricky Chicago X.
The torch is rated at 600ma on high. User _the_ measured 570ma. That's 95% of the stated draw, well within the margin of error.
That current draw will provide roughly one hour of use at the highest setting, without self-destructing or setting something on fire.
To state that is is under-powered is one of pure opinion, rather than fact.
I fail to see how the facts are tricky...
It is underdriven according to the LED manufacturer, not the flashlight one, we were talking about different things I see.
The LED manufacturer rates the XP-G at 350ma for 100% output.
600ma is ~150% of the rated luminous flux.
Technically, you could correctly say that this torch is OVERdriven. :)
The manufacturer states the max current is 1.5A anything under that is under-driven in my opinion.
Chicago X, I think you're misinterpreting the charts in the data sheet. They're not saying that the XP-G produces 100% of its output at 350 mA. They're saying that "if we arbitrarily select the 350 mA current level as being 100%, then...". It's like a baseline. It's similar to if we arbitrarily select "normal driving speed" to be 50 km/h, and take measurements at that speed, then we have a baseline for comparing with measurements taken at other speeds.
In fact, you can see from the flux vs. current chart that the xp-g can easily produce WAY more output than the 350 mA level, just like a car can go way faster than 50 km/h.
And even the 1.5 A "maximum" specified by Cree is not really a maximum, because the LED will not fail at 1.50001 A if it did not fail at 1.5 A. For example, Cree specifies the maximum current for their XM-L as being 3 A, but BLF member Match did a great test, running the current up to 4 A and beyond (with a huge heat sink). The LED will probably deteriorate faster at currents above "maximum", but even at 1.49 A or lower, if you don't heatsink the LED well it will deteriorate faster. If you were to try using an xp-g or xm-l with no heat sink at all, it would fail at a current much lower than its rated maximum.
I understand the charts, but thanks for the detailed reply !!!
My point was that 'under-' or 'over-driven' can be a bit subjective. :)
That is why I said it was a bit tricky ;)
