Yes! My 5C came in the mail yesterday. I love the UI more than my S10. And that tint…whoah. It looks maybe too yellow inside but outside it’s amazing. I walked around my property for 20 min just checking things out with my new light. If I got a 1A do you think it will be brighter than the 5C? Great little light.
do you think they are 940 lumens in real life or is that overstated? how does it compare against an olight s1 in brightness? especially since olight s1’s are selling for 26 bucks USD on sale on banggood
M3 lumens is overrated, and I have already put a note at the beginning of gb thread . Actual lumen value is about 600lm-650lm. You will be able to achieve slightly over 700lm with the help of copper MCPCB mod and imr cell.
Of course it was over rated, so were most of the women I dated
Didn’t stop me for going back for more.
600 lumens on a 16340 is pretty much par for the course, they are probably doing you a favor not being 900+ as it will just drain the already small cell faster.
Still a good light for the money.
Later,
Keith
I measured my M3 5C stock, but using an EFEST V2 550 mAh cell and got:
lumens: 680 @start, 658 @ 30secs
Then after reflowing the stock LED on a 16mm Noctigon and replacing the stock LED wires with good, shorter 24 AWG, I got:
lumens: 734 @start, 724 @30 secs (notice there is less drop now over the first 30secs? That's because of the copper DTP star!!)
For a CW 1A, I'd expect or guess 10-15% higher on a good IMR cell. We usually quote the 30 second time as the lumens measurement, as according to ANSI/NEMA FL1 standards.
So for a stock CW 1A M3, I'd expect to see 720-740 rated output lumens on a good IMR cell. Not sure how that compares to the supplied cell, might be close.
Of course, this assumes (big assumption) my light box is well calibrated (I think it's decent ).
Oh boy, I'm think'n yes. Wish I could recall how I did it . Hhhmmmm. Ok - just reviewed my pics, photobucket OnTheRoad M3, it's start'n to come back. The reflector threads in, so use a good tweezer or pointed needlenose to remove it. The pill assembly comes out the top - nothing special holding it in. Maybe some taps from the tube end are needed, I'll typically use a big nail set, well way over-sized nail set - whatever you may call it. No need to remove the side button.
My M3 has a significant parasitic drain. Noticed the cell was down to 2.5A, and then measured it at ~6 mA, but the reading is erratic. I then tested other lights and all faired well - steady, much lower readings, even with an indicator LED lit up. A stock X6R measured 0.565 mA which is considered very high. Most well designed lights measure 0.020 to 0.040 mA, or even less.
In freeme's review, he mentioned 7 umA, which I don't know what it means, but thinking he means 0.007 mA, or 7 uA. So my light might have a problem with the driver. It's the only one I measured that has a consistently erratic reading. I did mod the LED, MCPCB, and used heavier gauge LED wires, so possibly I ruined something in the mod.
