Okay, I misunderstood what you were saying. Yes, if you’re looking for anything even slightly resembling a thrower, you don’t want the Olight S1A Baton. On the other hand, if you’re looking for pure flood, you also don’t want the Olight S1A Baton. I like the S1A because it has a beam which resides in the middle between those two extremes. To me, that’s more useful for my purpose. Your mileage may vary.
As for the 14500, it looks bigger because it is both longer and skinnier than the 16340. So, the 14500 looks like a full cell, while the 16340 looks like a half cell. But, in calculating the nominal dimensions, it is only just over 12.5% larger in volume. If you look at the mAH ratings of some of the cells at Mountain Electronics (or any other site that has a variety of cells), you will find that they are close. Some of the higher rated 14500’s have more capacity than some of the 16340’s. But, some of the higher rated 16340’s have higher capacity than some of the 14500’s as well. The 18350 looks like it is just barely any bigger than the 16340, yet it is over 30% larger than the 16340 and almost 16% larger (by volume) than the 14500! My point is that the size difference looks like a lot more than it actually is. The 14500 is a small cell. It’s an optical illusion.
Well, i was contacted by Olight as well and im waiting for it to arrive, dont know if that will happen or not because most others already received the light. I already ordered some things for my first review of a light like a new tripod, a clamp with tripodmount for the light, LED bulbs for good lighting etc…
Im not that interested in cracking this thing up because im not a modder at all, all my lights are stock. Im sure many ppl here just want a review, beamshots etc. To see the guts of the light is interesting but in the end it doesnt matter to me. I appreciate it because sometimes it shows loose screwes or in case of the Astrolux S41 flaws with the screws, so i like it when somebody has the balls to open that thing because the chances are good that the light will be in a poor shape afterwards
I’m guessing all the innards of this light are pressed in from the front, and then that blue-coated bezel ring is pressed — or screwed — down over the lens to hold it all in.
Because I don’t see another seam on the body anywhere that would separate the battery tube from the head. All one piece, plus the tailcap??
Well, like I said, I won’t be taking mine apart any time soon. But, I can speculate. It’s probably put together like other Batons of the past, my S20-L2 for instance. It was much as you say. The whole pill and reflector assembly was press fit in. The bezel un-screwed from the front, and the pill could be pressed out from the back with a rod of some type. I used a wooden dowel rod. The button is also press-fit into the side. There is a tiny tactile switch installed in the pill, and the plastic side button had a piece of silicone on the back of it to press against the switch. When I pushed the pill out, it hung up on the silicone part and ripped a piece of it off. Then, the part that remained isn’t long enough to press the switch any more. If you’re super careful pushing the pill out, you may be able to get it without damaging anything. Others have done it before. Some have even modded Batons before. So, it isn’t really that difficult unless you’re me.
I’ve opened some pretty tight Olights with a sheet that exercise elastic in the palm of one hand, and jamming the bezel down and twisting with the other hand. You can lay on a surprising amount of torque that way, and not mark or dent the bezel.
Warming it up good in a ZipLok bag dunked in hot water doesn’t hurt either, if there’s any glue to soften - although I don’t recall any signs of glue in any of my Olights. They were just threaded, and tight.
Well no need to re-think things when the solution is a couple posts before yours (post #26)
I’ve opened both S1 and S2, and there’s no twisting needed at all.
I know, but my Samsung phone camera sucks for beam shots. Sorry about that. Here is mattlward’s review of the S1A. He covered a few things that I didn’t, including some great comparison beam shots!
Bravo X3 above for the links to the two disassembly videos. Reposting just to have the unobfuscated links handy:
I love it. Big knife, big hammer, careful work, and the flashlight comes apart for improving the emitter.
I hope the Olight engineers are following this and thinking, hmmm, we could make our products a lot easier to improve if we started putting them together better …
Had a second oddity — no timer involved this time, I’d just been using the strobe in crosswalks, turning the light off in between streets.
Using a different li-ion cell.
After a few blocks, I came to another croswalk, triple-clicked — nothing.
Tried all sorts of clicks — nothing.
No light at all.
Took the tailcap off, put it back on, and the light is back to normal.
I love this little light and it instantly became my favorite EDC. But I noticed that it wasn’t remembering the mode I last used even though it’s advertised as having memory mode. I assumed it was defective and wrote to Olight in the US. I received a quick response that stated:
“The S1A will remember the mode just for 9min and then it will automatically change to medium.”
So it has 9 minute memory mode only. Not terribly useful. A minor inconvenience.
