Hmmm? I chose this one because it has been tested, it’s the simplest circuit, and it can be found for cheap. The original tp can still be found and it seems the tpower clone works well too. But the source is everything and you are right that most can’t be trusted even when asked about the chip. I will look into some other chips and see if there are any good ready made circuits for them.
For easily available parts (and alternative to TP4056) you could base it on the Xtar MC1. They’re getting pretty cheap and are known to be reliable. I forget what chip they use, but someone identified it as a common one.
TP4057
Doesn’t have a solid CC phase, current begins dropping right away. This isn’t harmful but it is slow. HKJ’s review (2x tp4057 were used in the original ml-102). There are certainly better choices, but still, a couple tp4057 might be safer than random 4056 clones. There is a decent chance they are also cloning the tp4057, but the 4056 chips you know are random clones.
Microchip Technology chips (as well as many others linear li-ion charge controllers) use extremely simple circuits. Two caps, current set resistor, optional indicator led. Circuit and component values are in the datasheet. Adafruit and sparkfun also have chargers using those common Microchip Technology chips. And they provide open source Eagle files for their boards.
I haven’t seen anyone chart the charge profile of any of the 4056 clones.
You have a recent, reliable source for the original tp4056 NanJing Top Power chips (with stylized TP logo)? Please share?
Looking forward to seeing this come to fruition. A BLF driver with built in charging would be sweet! Think of the mods and/or scratch builds that can be done!
Honestly it wouldn’t be hard to do, the hard part will be making a generic driver/charge combo board that will work in multiple hosts. The OP looks like a separate little charger board that you would stack on an existing driver, which might be the best route. (definitely the most versatile.)
Ok, I misunderstood. A combination driver/charger is what I thought the target was here. I thought the design in the OP was meant to just be a starting place for design.
I agree, that would be awesome, it’s just more specialized than generic. Using EagleEye as an example, If we made a board that fit the driver pocket and charger cutout/port in an X6R (which we sorta did), it wouldn’t work at all in an X5R, and vice versa.
As a result of the feedback on the above circuit I redesigned a board using the ME4057 charger. This IC has solid specs and includes reverse polarity protection, recharge, and overtemp protection. The new design is below. Please give me your feedback!
I would like to bring a design to oshpark but i am unsure how to do so. In fact, what you see below is as far as I have learned of the design software DipTrace. I do not know how to prepare the design for printing. I don’t know what to do with the different layers such as silk mask or even how they are edited. So I’ll be studying up on that if anyone wants to give some pointers.
Anyway, here is the new design. It is on a 17mm board but could be sanded to 16mm without trouble to the circuit.
It looks good! (Says the guy who doesn’t know anything about what he’s looking at :person_facepalming: ) You should contact Texas_Ace about using Diptrace and uploading to OSH Park. He uses Diptrace for all of his designs.
But a question: if I think about a light with build-in charging that I would like to upgrade, I think of the Supfire A2 (bad UI, low PWM). And in that light I would think of another approach: I would leave the stock board in, but cleared from components except for the micro-USB socket. That way the socket is fixed in its original correct position and I start with a big worry less. What I then need is an upgraded driver (a 17mm bistro driver would fit easily) and a minimised charging board that can be attached to the socket with wires, and looking at the number of components needed, that can easily be 10mm diameter (it does not even need to be round). Yet another approach could be starting from a one-sided driver (could be a bistro driver again, why not?) and add the charging components on the underside (it will be used floating so the battery side is not in use).
Just thinking out loud without the skills to contribute anything to an actual design :innocent:
Those are great observations! I have a couple a2s and feel the same way. I’ll look at it more and see if an fet +1 single sided version of TAs boards might hold this circuit. Also, certain lights that do not have charging, such as vg10, might be able to hold a board with a dremeled hole for the charge port. Lights without charging stock might be better candidates for the board as it is above. So I’ll also put together a board without the micro USB. This way it could be wired to any charging port desired.
I think I’ve found a way to use the stock charging circuit on the a2. It will add 16ua standby current in addition to the TA driver with Narsil. Not sure if that’s a big deal or not. I think I’m going to try it though.
I finished building the TA driver. I will flash it tonight and then hopefully tomorrow I can test it with the charging circuit from the a2. I’m not sure what implications it will have on the software. I’m not even sure if it will work at all but I’m going to find out:)
The driver is flashed with narsil triple. Narsil triple doesn’t have an indicator led support so it will only use the onboard leds when plugged in and charging. Tomorrow I need to remove the switch from the stock driver, isolate it from the contacts, and replace it with arctic silver or maybe epoxy. Idk? That way I can use the stock switch without turning the stock driver on when pressed. I am hoping that this will allow the stock driver to remain in standby mode only used for charging. All other functions will run from narsil.
