Review - GB UltraFire 950LM CREE U2 tactical flashlight
20 posts / 0 new
WestBam
WestBam's picture
Last seen: 1 day 14 hours ago
I want to introduce UltraFire tactical flashlight models available on the GearBest
Specifications:
Brand: Ultrafire
Lamp Beads: Cree XM-L2 U2
Beads Number: 1
Lumens Range: 500-1000 Lumens
Luminous Flux: 950 LM
Color Temperature: 6500-7500K
Switch Type: Clicky
Switch Location: Tail Cap
Feature: Anti-Roll Rugged Design,Cooling Slot of High Efficiency,Lanyard
Function: Camping,EDC,Hiking,Household Use,Night Riding,Walking
Battery Type: 18650
Battery Quantity: 1 × 18650 battery (not included)
Mode: 5(High-Middle-Low-Strobe-SOS)
Waterproof Standard: IPX-6 Standard Waterproof
The flashlight look tactical. Slightly smaller than the size of the convoy C8.
Battery uses a piece of 18650.
It’s got beautiful (zombie) green tail switch is GITD.
The body is connected to the pill screwed. Protected against rolling.
Pill is equipped with original CREE XM-L U2 LED. Better cooling than P60 dropin.
The bezel pushes down the OP aluminum reflector.
Everywhere there are rubber seals, protected against water.
The lamp heats up during use, so probably a good heat conductivity.
Light slightly bluish, no distractions like latticebright cheap fakes.
Unfortunately, there is no mode memory. Always start the next mode.
Measurement results:
High: 2,15A
Medium: 1,05A
Low: 0,47A
Weight without battery: 127g
Body lenght: 135mm
Maximum diameter: 43mm
Use uncoated glass plate on the head.
Pros:
tactical look
good cooling
good quality
cheap
looks waterproof
usable without modification
Cons:
No mode memory
Mid and low mode pwm
First generation CREE XM-L LED
Convoy C8, UltraFire 950LM, UltraFire WF-502B, Convoy S2+
Conclusion:
I liked this model during use. It is not as much power as Convoy C8, yet surprisingly high brightness. Hotspot no contrast due to the OP reflector. There is scattered light, but the hotspots good throws. Cheaply is a good thrower torch!
Comparative images in mid mode:
Comparative images in high mode:
Thank you for reading this, I apologize for my bad english.
A full review can be found on my blog. The site has a built-in google translator in the lower left corner of the page.
Edited by: WestBam on 04/26/2018 - 05:59
MG
Last seen: 1 week 1 day ago
Thank you for the review. I was wondering about the size compared to the C8.
WestBam
WestBam's picture
I was wondering the brightness. Nice throw!
tristanxoxo
Last seen: 4 months 1 week ago
Thank you very much for the review. Could you possibly post a picture of the switch? Also, would you happen to know the diameter of the driver?
WestBam
WestBam's picture
Tailcap exploded view:
Compared switch to omten they seem compatible:
Driver standard 17mm:
g_sintornillos
g_sintornillos's picture
Last seen: 1 day 5 hours ago
The led is a XM-L2 (second generation) or a clone, the photo is too small to distinguish whether it is a clone
Sorry for my bad English (gogole transtorla)
unknown00101
Last seen: 1 week 4 days ago
Looks like a pretty good deal for $12. Beefy pill and good anodization.
As for the next mode memory, I would try the lead pencil line across the capacitors trick.
Just take a sharpened pencil and connect the silver ends directly on top of the light brown rectangular components on the driver.
The Miller
The Miller's picture
Great review
Nice design, looks like those Scandinavian stealth marine ships
WestBam
WestBam's picture
Thank you guys!
Feels good positive feedback Beer
WestBam
WestBam's picture
You do not draw?
I’m Lama electronics such high levels. Oops
unknown00101
tru3s1lv3r
tru3s1lv3r's picture
Last seen: 1 month 3 days ago
Nice review. I was surprised at the quality for such an inexpensive light. At least compared to some other options in the same price range.
Aspiring Fhashlightaholic!
WestBam
WestBam's picture
unknown00101 wrote:
!{width:90%}http://i.imgur.com/uiPjdN7.png!
I understand it:
If the red line soldering method will be the last memory?
Sounds hard to believe, why did not you at the factory?
Are you sure you do not die in the driver? For only A17DD at home, it would be a bit strong Crazy
WestBam
WestBam's picture
Thaks tru3s1lv3r!
You’ve experienced, it’s not a bad flashlight Wink
unknown00101
The red line can be made with just #2 pencil lead. I’ve done it on around 10 of my budget lights. It has worked on all of them. Some people reported that it didn’t work for them, but I’ve never heard of it breaking anything.
If it works it should reset to high or low, X seconds after turning it off.
WestBam
WestBam's picture
So simple pencil drawing together?
Try it. Soon I report the final outcome Thumbs Up
WestBam
WestBam's picture
Ready.
Both top scribbled graphite pencil. Results: always starts with the high mode.
Even this is way better than the next mode start.
Thanks for the information! Thumbs Up Beer
tristanxoxo
Thanks again for the information and pictures…you did a great job! This looks like it has great mod potential. Everything look s super easy to mod.
unknown00101
WestBam wrote:
Ready.
You’re welcome, glad it worked out! Smile
I just noticed the driver spring in particular looks pretty tall and rather thin. If you can solder you may see some improvement in output if you were to bypass the springs.
WestBam
WestBam's picture
The driver is not determined by the maximum power consumption?
C8 8×7135 driver bridged everything they can only 2,8A maximum current drawn is not it?
Factory picks up the maximum. If bridging will be higher?
