(the slider on the right side of the actual page shows the pressure change moving hour by hour)
This light may just have a good seal — a change in air pressure can make those hard to open — but chilling a well sealed tube would lower the pressure inside and any seal would then suck in air (or water), too, which might explain …
I’ll watch this with mine. I noticed, right out of the box, that it took some fiddling before the slider would move at all. At first I thought they’d sent me a non-zoomie! Then suddenly it zoomed.
I lubed the o-rings with Nyogel and much better now. The i3 came pretty smooth, probably pre-lubed like it was on the threads. My U-F10 came with nothing on the threads as well. Others reported their U-F10 zoom slide worked fine, stock.
What a weird light that is.
None of the LEDs are centered.
Lol I let browser translate it and got this: 20w blue light night fishing light fishing light source 4 double hernia lights Ultra Violet Flashlight Fishing Taiwan fishing rod holder who
This thing must be extremely heavy
Funny, but the LED's don't have to be so well centered under an aspheric - the old "nut light" with multiple LED's worked the same way. The hot spot changes position going from LED to LED, but it all worked pretty good.
Warsun X50, I ordered one of these when they were on sale. I can not recommend them for modding as unless someone knows something I don’t they can not be opened up without damaging them.
It is too bad as the overall light is actually not that bad for the price. The heat path sucks but that could be improved with some work.
I decided to just leave it alone as it is basically the only AA flashlight I have now that is more then a pocket light. Think it was pulling around 1A? stock.
I bought a Brinyte B158 with an XP-L HI for my son’s upcoming birthday and to tell the truth, I’ve been playing with it all week. (Gotta make sure it’s working, right?)
It’s a fun light, the head makes it much too large for comfortable carry, but for campsite flooding and the critter spotting, it’ll be a worthy light to bring along. AdvancedKnifeBro’s review video clinched it for me.
I have a cheap twist zoom known as a SAIK SA 9 which has a long throw with a 18650 Battery.
It projects the die at maximum focus -
BUT - going slightly BEYOND maximum focus causes the beam to ‘cross over’ itself and become round at a similar size of the Die.
This could be done on purpose if manufacturers chose to do this.
This is a smaller die with high Candela so beam is visible from the side.
Pay attention;
1)At maximum focus the beam edges a foot in front of the light BUT viewed from the side- the beam edges are parallel= projects the die image.
2) At slightly BEYOND focus- the beam edges have a slight crimp where the beam NARROWS in front of the light 2-4 feet THEN becomes nearly Parallel again=
Projects a ROUND Image but still the same throw,
Round Image at 20 feet is slightly larger than die image but same throw and laser like visible beam and 200 to 400 meter throw.
I would like to see this same thing in a Turbo medium die size at 2.0 to 2.5 amps .
With a glass lens and maximum current this might be 700 to 1000 meters of throw .
I am not an optics expert but logically what is happening is the Beam is crossing over and the image is reversed right to left and slightly blurred to round….
They are not 5000 lumen lol and they are not
XML LED but they are
actually flashlights[ 1 out of 3 ].
They are a push Zoom quite well made and use one of the smaller LED dies.
The battery says Skywolfeye 5000ma another impossibilty but probably better than those blue Ultrafire.
The light itself has good focus about 200 to 300 meters of throw…
guessing about 300 lumens.
Quite well made for ridiculous low price says
HWA WYS
ULTRAFIRE on one side and CREE on other.
Has beam visible from side about diameter of a penny meaning high Candela and does not get hot at all.
Nice flood mode.
*I wonder what would happen with a De-domed
LED on this at about 2 Amps ?
This uses 18650 and is small and bright.
Light is about 1.6 times taller than a 18650.
Headstands and tailstands.
About 3 dollars with a battery and cheapo charger- the ultimate budget light!
*Anyone want to mod a few of these and send me one back - I will send a few extras for you to keep…
These are a great little light as a gift for someone to keep in car or purse etc. and you might like them for EDC very small but powerful…has low high and strobe.
It all depends how much you want to pay for good mod.
Maybe you are not aware but proper modding could exceed price of such light for 5X.
So even few extras is low
Depends on where you live, and how much you buy and ship besides the host — drivers and emitters add up.
You should look up how much you’re going to have to pay for those, and figure shipping to and from whoever offers, if anyone does want to do it for you.
But seriously — once you’ve bought the drivers and emitters, you’ll find a soldering iron is all you need to add, and swap them yourself.
I have bought the “WolfEye” cheapies and wouldn’t bother modding them, they feel like they’re made out of tissue paper.
I doubt they can handle any more heat/power than the stock parts dumps into them.
Agreed “Sky /pic wolf head / eye”/skywolfeye lights are the worse budget / cheap lights I have bought. I have several lights two times, looking the same but when one has skywolfeye on it the quality is worse.
That’s strange. Mine opened up just fine. If I recall the pill might need a strike with a mallet before it unscrews though. Look through the x65 and “nut light” threads
Got a link? I searched and searched when I got mine but could not find anything. I can’t even figure out how the pill is installed so I can’t figure out how to remove it.
