ENEDED
Interested in one with Cree leds and 18650 tube.
Please put me down for (1) Nichia 219B and 18650 tube.
Thanks,
Mike
1 Nichia for me pls.
Cheers,
1 Nichia 219B and 18650 tube.
Thanks!
I’m in for 2 with 2 18650 tubes
This might be obvious but I am assuming they arent making a heat treated extension tube to match the heat treated version?
How hard is it to heat treat oneself?
… CREE XP-G3 version with a high drain lion must deliver more than 1600 lumen!! (?) …
Interested in 1x Nichia and 1x 18650 extension tube!
+1 K-wong/nichia/18650
Thank you!
Please put me down for One Nichia+18650 Tube+Box
Thanks.
Please one S with 18350 and 18650 Tube ,Nichia-LED´s.
Regards
Jens
1 heat-treated with 18650-tube and XP-G3’s for me, please! :sunglasses:
Forgot to say Cree version for me please…
I’m on the list, the only one with no preference.
Might as well plan on the 18650 tube as well.
+1 Nichia and extension tube
Actually in for 2 Nichia w/ Tubes
I assume that also these are made by Manker? So BG is working with them again?
This must be one heavy light!! And as noted above with the SS stopping the heat, it will have a lot less surface to shed it. Looks good though :slight_smile:
Jos here is something from the OP :
Difference between S41S and S41 aluminium:
Manufactured by new supplier.
New logo.
Missed that :slight_smile: . I will be curious about the ledboard then, it could even have been improved compared to the Manker one :innocent:
I think that they will use led board and driver from Manker . But it’s just a guess , we will see .
I’m interested in a heat treated Nichia 219b version with 18650 tube (assuming the 18650 tube is also heat treated). If the 18650 tube isn’t available with heat treating I don’t want heat treating on the S41S.
