Gearbest New Arrival: March 22nd, Convoy H1 CREE 29.99$
August 19 update
products of category of the LED Lights & flashlight http://www.gearbest.com/led-lights-c_11264/ (link is external) ( full-price item)could get 8% off discount via the coupon of GBLED2016
**1.”**CRELANT V4A LED Flashlight - 6500K GRAY* “:http://www.gearbest.com/led-flashlights/pp_428556.html?wid=21 29.89$
● CREE XPL HI LED, delivering max 1095LM output
● 6500K and 5300 - 5400K for your choice
● 5 modes: high - low - strobe - SOS - dimming light
● Side switch and twisty tail switch, side switch of infinitely variable brightness function
● IPX-8 waterproof standard, let alone rainy days
● SMO aluminum reflector with spotlight and 523M long beam
● Body with anti-slip knurling, cooling slots of high efficiency
● Powered by 4pcs AA batteries, ensuring max 95min runtime
2. Eagle Eye X7 LED Flashlight - XM-L2 U3 1A BLACK $20.10
● Cree XPL HI 1A / 3A or XM-L2 U3 1A LED - Max 1100LM output, 5 modes: turbo 2.8A - high 1.2A - mid 0.2A - low 0.01A
● 6000 - 6500K ( 1A ) / 5200 - 5500K ( 3A )
● White light is of high brightness, neutral white light is close to daylight, ensuring the users to identify and recognize the target accurately
● Instant strobe - Double click at any mode to enter Strobe
● Memory function - Turn off the flashlight for more than 2s, turn on again for previous mode
● Low-voltage warning -When battery voltage drops down to 3V, the light flashes to inform users
August 24 update
1. ANGRYFOX Playfox K1S LED Keychain Light 17.90$
● K1 made of aluminum alloy in back, K1S made of stainless steel in silver
● Comes with red, blue and green rubber caps, which act as filter and gives you more fun
● Cree XP-G2 R5 LED, max 100LM output
● 4 modes ( Mid mode default ): high - mid - low - strobe
● Constant current circuit ensures constant brightness
● Streamline pendant design, can be attached to necklace or keychain
● IPX-8 waterproof standard ( 2m ), let alone rainy days
● Reverse polarity protection prevents inappropriate battery installation
● Acrylic optical lens, max beam distance up to 45 meters
● Powered by AAA battery, enduring max 110h runtime
2. CRELANT E3 LED Flashlight - BLACK Cree XPE 7.87$
● Lamp Beads: Cree XP-E
● Beads Number: 1
● Lumens Range: 1-200Lumens
● Luminous Flux: 140-300Lm
● Power: 3W
● Color Temperature: 6500K
● Switch Type: Twisty
● Feature: Lightweight
● Function: Camping,EDC,Hiking,Household Use,Night Riding,Walking
● Battery Type: 10440,AAA
● Battery Quantity: 1 x AAA / 1 x 10440 (not included)
● Mode: 4(Low - Mid - High - Strobe)
● Waterproof Standard: IPX-8 Standard Waterproof
3. Imalent HR20 LED Headlamp - BLACK 49.95$
● The HR20 is a lightweight and multifunctional headlamp, weighting merely 46g
● Utilizing CREE XP-L HI LED in conjunction with copper MCPCB, max 1000Lm output
● Rotatable brightness adjustment to any desired brightness, coping with multiple unexpected accidents
● Built-in Micro USB charging port, the battery in the HR20 can be charged conveniently
● Innovative switch design for easy operation
● Optimized lens and reflector for impact resistance and excellent beam
● IPX-8 standard waterproof (2m) for severe weather
● Advanced temperature control module prevents over-heat
● Aerospace grade aluminum alloy construction with military hard-anodized finish
● Headlamp and flashlight dual use, necessary lighting tool for inspection equipment and outdoor reading
August 26 update
1. Sanrenmu 1555Ti Foldable Knife - TITANIUM GREY 17.79$
- 8CR13Mov stainless steel blade and stainless steel handle
- Titanium coated surface, beautiful and durable
- With rivet on the blade, more convenient for you to open the knife
- Semi-automatic quick opening feature, faster to unfold / fold the blade than normal knives
- With hanging clip on handle, convenient to carry
- Lightweight and pocket size
2. Sanrenmu 4107 SUX - LK Mini Foldable Knife with No Lock - GRAY 6.59$
- 8CR13Mov stainless steel blade and aluminum alloy handle
- With groove on the blade, more convenient for you to open the knife
- Special anti-slip handle design
3. Sanrenmu GB8 - 707 7007 LUP - GH Liner Lock Foldable Knife - BLACK 8.99$
- 8CR14Mov stainless steel blade and G10 handle
- With hanging clip on anti-slip handle, convenient to carry
P.S. More new arrival Sanrenmu products can be found HERE
hello Gearbest,
no more free registered shipping over 40$ ? :frowning:
Hi Patrickbateman,
could you please PM me with your order number
Best,
May
products of category of the LED Lights & flashlight http://www.gearbest.com/led-lights-c_11264/ (link is external) ( full-price item)could get 8% off discount via the coupon of GBLED2016)
September 1 update
1. Ganzo G746 - 1 - CF Foldable Knife - BLACK $16.37
- 440C stainless steel blade and carbon fiber handle
2. Brother Mid Lock Foldable Knife with Stainless Steel Handle - SILVER $15.39
3, Harnds Cheetah Fixed Blade Knife - YELLOW $23.99
- 8CR13Mov stainless steel blade and wooden handle
- Full tang design, surprisingly tough
- With leather sheath, safe and convenient
- Lanyard hole on the bottom of handle, convenient to carry
- Suitable for traveling, mountaineering, venturing, hiking, collection, and so on
4, Sanrenmu SK021Z Multi-use Toolkit - SILVER $3.39
- Multifunctional tool, it can be used as spoke wrench, hex wrench, bottle opener etc.
- Made of stainless steel, durable to use
- Mini size and lightweight, convenient to carry
- Equipped with a key ring
Hello,
i have not ordered yet, i was waiting for an explanation… :frowning:
what has happened to prices? sudden rise in prices?
Hi Guys
there is problem with our system recently for the tracking fees, our related staff is working on it now, so sorry will make you to wait for a few days
Best,
May
Hi serp, if promotion is over or cost raised, then price will be rise, which products do you love, I could ask our related staff if they could promote it again
All flashlights convoy risen by +–25%
products of category of the LED Lights & flashlight ( full-price item)could get 8% off discount via the coupon of GBLED2016
September 3 update
1.Klarus XT11GT Tactical LED Flashlight - BLACK $89.95
Brand: KLARUS
Model: XT11GT
Lamp Beads: Cree XHP35 HI D4
Beads Number: 1
Lumens Range: >1000Lumens
Luminous Flux: 2000LM
Luminous Intensity: 40401cd
Switch Type: Clicky,Tactical Switch
Switch Location: Side Switch,Tail Cap
2. AIMAI AK02 55Lm Capsule LED Flashlight - GRAY $2.91
Brand: AIMAI
Model: AK02
Lamp Beads: Other
Beads Number: 1
Luminous Flux: 55LM
Switch Type: Twisty
Feature: Lightweight,Tail Stand
Battery Type: 16340,CR123A
This little AIMAI light would be perfect if it had integrated usb charger…
http://www.gearbest.com/led-flashlights/pp_44168.html
Convoy M1 $17.59 - flash sale will be good (when it back to stock)
Gearbest’s Deals ——- Sep 6th, $16.99 for Convoy M1 ( 2 in stock now )
Hi Serp, you could find it more cheaper deal here
18 september update
Category coupon for full priced product ( except some special products ) flashlight http://www.gearbest.com/led-flashlights-c_11265/
price: 12% off discount - coupon: LIG12OFF
1.Nitenumen NE01 Updated VER LED Flashlight - UPDATED VERSION
● CREE XP-L V5 LED, maximum output up to 1060 Lumens
● 7 modes: turbo; high; mid; low; moonlight; strobe; SOS
● Lock-out function prevents accidental activation
● Built-in Micro USB charging port, intelligent Li-ion battery charging circuit
● User-friendly red and blue battery indicator, low-voltage warning
● Aviation aluminum vacuum electroplating reflector offers 236M far beam
● Intelligent constant current driver circuit ensures constant output
● Precise temperature control system adjusts output according automatically
● 320h ultra long runtime, compatible with 18650, 16340 and CR123A batteries ( not included )
2. WUBEN E346 300LM CREE XP-G2 LED Flashlight
● Perfect for home use, camping, hiking, searching, trekking, hunting, fishing, car emergency, etc.
● CREE XP-G2 LED gives out super bright and stable light beam with low energy consumption
● Two lighting modes ( low, high ) are suitable for different occasions
● Special appearance design, wear-resisting, impact resistant and scratch-resistant
● IPX8 waterproof function allows you to use it in any weather
● Made of aluminum alloy, durable to use and sturdy in hand
● Twist the head to turn on the light and adjust the brightness
● You can charge the battery rapidly by any devices with a USB port, such as computer, desktop, laptop, power bank
● The key ring for easy carrying
● Powered by 1 x 16340 800mAh battery ( included )
● Impact resistant to 1.5M
● Lightweight, compact and small size
● After fully charged, it can be used for 1.2H at high brightness and for 11.5H for low brightness
● Light source: CREE XP-G2
3. WUBEN I333 1200LM CREE XPL-V5 LED Flashlight
● CREE XPL-V5 LED gives out super bright and stable light beam with low energy consumption
● Seven lighting modes ( moon, low, middle, high, super bright, strobe, SOS ) are suitable for different occasions
● Lotus head can smash the glass easily, which can help you to escape as in emergency
● With the power indicator function, you can know the battery power clearly ( when button W is blue, the battery power is more than 30pct. When button W is red, the battery power is more among 30 - 10pct. When button W is red with flicker, the battery power is less than 10pct )
● The switch is on the tail of the light, convenient to use by one hand
● With the clasp, easy to hang in outdoor bag and jeans
● The rope for easy carrying
● Powered by 1 x 18650 2600mAh battery ( included )
4. Manker E11 Mini LED Flashlight - 1A 6500K
●Brand: Manker
●Model: E11
●Lamp Beads: Cree XP-L
●Beads Number: 1
●Lumens Range: 500-1000Lumens
●Luminous Flux: 800 (14500) / 400Lm (AA)
●Color Temperature: 6500K (1A) / 5000K (3D)
●Switch Type: Clicky
●Switch Location: Side Switch
●Feature: Cooling Slot of High Efficiency,Lanyard,Lightweight,Pocket Clip
●Function: Camping,EDC,Hiking,Household Use,Night Riding,Walking
●Battery Type: 14500,AA
●Battery Quantity: 1 x AA / 14500 battery (not included)
●Mode: 4Mode (High > Middle > Low > Lower)
●Mode Memory: Yes
●Waterproof Standard: IPX-8 Standard Waterproof
Interesting new lights, the updated nightnumen without the bug and the wuben brand, thanks for sharing.
20 september update,
Category coupon for full priced product ( except some special products ) flashlight http://www.gearbest.com/led-flashlights-c_11265/ can be bought for additional 12% off discount, with the use of the code - LIG12OFF
1. ThruNite TN42 LED Searchlight - 5000K BLACK
● Utilizes Cree XHP35 HI LED delivering up to 2000Lm output
● 6000K white light and 5000K neutral white light are available
● Multiple outputs: 5 constant brightness outputs and emergency Strobe mode
● Optimized SMO reflector for maximum 1550m throw distance
● Instantly access to Eco, Turbo and Strobe at any time
● Runs on 4pcs 18650 batteries ( not included ), which provides up to 58 days runtime
● IPX-8 ( 2m ) waterproof standard is ready for all-weather conditions
● Constructed from T6061 aero-grade aluminum alloy in military-grade hard anodized finish
● Toughened ultra-clear double glass lens with anti-reflective coating, 99pct light transmittance
Outdoors & Sports ( including knives ) http://www.gearbest.com/lifestyle-c_11270/show.html?odr=trending can be bought for additional 12% off discount, with the use of the code - OUT12OFF
2. Ganzo G7531 - BK Foldable Knife - BLACK
- 440C stainless steel blade and G10 handle
  • Lightweight and pocket size
3. Ganzo G7533 - GR Foldable Knife - GREEN
- 440C stainless steel blade with titanium coated and G10 handle
26 september update
Category coupon for full priced product ( except some special products ) flashligh (link is external) can be bought for additional 12% off discount, with the use of the code –*LIG12OFF*
1. JETBeam JET - II MK EDC LED Flashlight - $29.45
_
Lamp Beads: Cree XP-L HI
Beads Number: 1
Luminous Flux: 510LM
Luminous Intensity: 4800cd
Color Temperature: 6500-7000K
Switch Type: Twisty
Feature: Lightweight,Pocket Clip,Tail Stand
Battery Quantity: 1 (not included)
Mode: 4 (High > Middle > Low > Lower)
Waterproof Standard: IPX-8 Standard Waterproof (Underwater 2m)
2. AIMAI C16G LED Searchlight - $24.46
_
Lamp Beads: Cree XML-T6
Beads Number: 12
Lumens Range: >2000 Lumens
Luminous Flux: 2900LM
Color Temperature: 7000-7500K
Switch Type: Clicky
Feature: Cooling Slot of High Efficiency,Stainless Steel Bezel
Function: Camping,EDC,Exploring,Household Use,Night Riding,Rescue,Search,Seeking Survival,Walking
Battery Type: 18650
Battery Quantity: 4 (not included)
Mode: 5(High-Middle-Low-Strobe-SOS)
Waterproof Standard: IPX-7 Standard Waterproof
28 september update
products of category of the” LED Lights & flashlight”:http://www.gearbest.com/led-flashlights-c_11265/ ( full-price item)could get 8% off discount via the coupon of GBLED2016
1. Zanflare F1 LED Flashlight XPL V6 - 39.99$
Lamp Beads: Cree XP-L V6
Beads Number: 1
Luminous Flux: 1700LM
Color Temperature: 6000-6500K
Switch Type: Clicky
Switch Location: Tail Cap
Battery Type: 18650,CR123
Battery Quantity: 1 x 18650 or 2 x CR123 batteries (not included)
Mode: 7 (High; Middle; Low; Ultra-low; Strobe; SOS; Location Beacon)
Mode Memory: Yes
Rechargeable: Yes
