Hi serp, if promotion is over or cost raised, then price will be rise, which products do you love, I could ask our related staff if they could promote it again
● CREE XP-L V5 LED, maximum output up to 1060 Lumens
● 7 modes: turbo; high; mid; low; moonlight; strobe; SOS
● Lock-out function prevents accidental activation
● Built-in Micro USB charging port, intelligent Li-ion battery charging circuit
● User-friendly red and blue battery indicator, low-voltage warning
● IPX-8 waterproof standard ( 2m ), let alone rainy days
● Aviation aluminum vacuum electroplating reflector offers 236M far beam
● Intelligent constant current driver circuit ensures constant output
● Precise temperature control system adjusts output according automatically
● 320h ultra long runtime, compatible with 18650, 16340 and CR123A batteries ( not included )
● Perfect for home use, camping, hiking, searching, trekking, hunting, fishing, car emergency, etc.
● CREE XP-G2 LED gives out super bright and stable light beam with low energy consumption
● Two lighting modes ( low, high ) are suitable for different occasions
● Special appearance design, wear-resisting, impact resistant and scratch-resistant
● IPX8 waterproof function allows you to use it in any weather
● Made of aluminum alloy, durable to use and sturdy in hand
● Twist the head to turn on the light and adjust the brightness
● You can charge the battery rapidly by any devices with a USB port, such as computer, desktop, laptop, power bank
● The key ring for easy carrying
● Powered by 1 x 16340 800mAh battery ( included )
● Impact resistant to 1.5M
● Lightweight, compact and small size
● After fully charged, it can be used for 1.2H at high brightness and for 11.5H for low brightness
● Light source: CREE XP-G2
● CREE XPL-V5 LED gives out super bright and stable light beam with low energy consumption
● Seven lighting modes ( moon, low, middle, high, super bright, strobe, SOS ) are suitable for different occasions
● Lotus head can smash the glass easily, which can help you to escape as in emergency
● With the power indicator function, you can know the battery power clearly ( when button W is blue, the battery power is more than 30pct. When button W is red, the battery power is more among 30 - 10pct. When button W is red with flicker, the battery power is less than 10pct )
● The switch is on the tail of the light, convenient to use by one hand
● With the clasp, easy to hang in outdoor bag and jeans
● The rope for easy carrying
● Powered by 1 x 18650 2600mAh battery ( included )
Category coupon for full priced product ( except some special products ) flashlight http://www.gearbest.com/led-flashlights-c_11265/ can be bought for additional 12% off discount, with the use of the code - LIG12OFF
● Utilizes Cree XHP35 HI LED delivering up to 2000Lm output
● 6000K white light and 5000K neutral white light are available
● Multiple outputs: 5 constant brightness outputs and emergency Strobe mode
● Optimized SMO reflector for maximum 1550m throw distance
● Instantly access to Eco, Turbo and Strobe at any time
● Runs on 4pcs 18650 batteries ( not included ), which provides up to 58 days runtime
● IPX-8 ( 2m ) waterproof standard is ready for all-weather conditions
● Constructed from T6061 aero-grade aluminum alloy in military-grade hard anodized finish
● Toughened ultra-clear double glass lens with anti-reflective coating, 99pct light transmittance
Category coupon for full priced product ( except some special products ) flashligh (link is external) can be bought for additional 12% off discount, with the use of the code –*LIG12OFF*
products of category of the” LED Lights & flashlight”:http://www.gearbest.com/led-flashlights-c_11265/ (link is external) ( full-price item)could get 8% off discount via the coupon of GBLED2016
The brass version is also a beauty, but I'd pay no more than $60 and they want $190? Yep, a little insane. I can get 1200 out of a 18350 light for a whole lot less for sure.
Hhmm, $10 for a Convoy S2+ 18350 host, maybe $12-$15 for the LED and driver.
