BTW: It is really heat treated or is it some sort of rainbow effect anodizing that we have seen on many ecig related products - there is a name for that but don’t remember it right away…?
Please check mcpcb, is it still manker?
Is this the X6 driver Board with the free space for bleeder resistor and the tailcap with place für LED and resistor? Plastic-Washer in the Tailcap?
Are the threads the same as the black version?
Has the XP-G3 a yellow tint? White Wall shots please.
Whats the weight without battery, clip and lanyard?
I’ve no clear idea how it works, but as far as i can tell from pictures on the web, heat treated steel does not produce such ‘supernatural’ rainbows. They look more faded, sometime uneven… not the full spectrum… When it looks so good it probably is some sort of cosmetic finish i would think?
Yeah, I’m not so keen about the “heat treating” anymore. I think I will stick with standard light SS instead. If you’re still updating the list, please change mine from heat treated to normal (with the 18650 tube).
If it is indeed rainbow pvd coated like it appears to be the finish should actually be quite durable. Much more so than bare non magnetic stainless which will scratch very easily. I just don’t personally like the rainbow finish with the copper. Now an all blue pvd like on some of the Olight bezels would be sweet.
