This. This is very convenient and easy mod for 105c. Two extra wires and new firmware. Too bad it didn’t get done here.
Though I guess even slightly altering a PCB layout is a too massive undertaking for a budget-friendly flashlight.
When I went to sleep, this thread didn’t exist. Now it’s already at 90+ posts. That’s a lot of activity in just a few hours!
I tried to fit as much as I could into a standard nanjg 105d driver, and make it useful for a wide audience. This new C8 is the first item to have the new firmware. I assume it should also work in anything with a compatible driver, like the S series and maybe M1/M2 or BD series.
So far it’s called bistro-mini, because it’s based on bistro but half the size. People have told me this is a bad name though, so I’m considering some others…
biscuit or biscotti, to keep the tie to bistro but indicate something smaller
converge, convertible, conveyance, convect, convene, convey, convalesce, … to tie into the Convoy brand
“Jared Stinks”, as suggested by Jared (J-Dub74)
Any preferences?
(edit: my preference is to not put my name in the title)
To make the output as stable as possible no matter what type of 7135 chips (or how many) are used, moon mode has slow PWM. I’ll have to measure to be sure, but moon (0.1%) is either 1 kHz or 2 kHz. This also means it’ll be up around 0.8 lumens instead of the usual 0.2 lm, but that’s as close as I could get it with this hardware.
The low (1%) mode runs at 8 kHz (to make it more stable), but this is still 2X the speed of the older nanjg drivers.
Everything else runs at 16 kHz, about 4X as fast as the older nanjg drivers.
I had LVP set to 2.8V initially, but during tests I couldn’t get it to trigger before the cell’s built-in protection went off. So, it’s now set to step down when the cell gets under 3.0V. If it stays that low even on the lowest mode, it’ll eventually shut off the emitter and go into a low-power standby mode.
The problem is that new driver hardware was beyond the scope and budget of this project, and Convoy doesn’t have a lot of resources to develop it or get the hardware produced right now. So, the driver is the same hardware as before, but with new firmware to improve it as much as possible. The nanjg drivers are actually pretty nice, and inexpensive, so they work pretty well.
Maybe in the future sometime Convoy can get new driver hardware, but not yet.
Also, what pilotdog68 said earlier.
The reason for the minimum of 6/255 (or 7, or 8, or 3, or …) is because the 7135 chips take a few “frames” to open, like a slow-moving door. They’re not as fast as a FET. This is exactly the reason why moon mode runs at a slower speed.
The minimum usable pulse duration varies with the number and type of 7135 chips, the type of LED, the battery voltage and brand, etc, and those factors are all variable for this project. It could be anywhere from 2 to 16 7135 chips, several types of LED, a variety of hosts, and so on. So the most hardware-sensitive aspects were optimized for stability, which means slower PWM on moon.
As usual, the sources are available for anyone who wants to modify it.
Yes, 50-100% can be done but doesn't really show much of a difference. The highest I would typically go is 40%, sometimes 50%, as do most high mode count lights - just doesn't make enough difference. Best usage is a spread in the lower levels.
The stated outputs are the power level, which can be misleading. Throw distance follows an inverse square law, while perceived brightness tends to follow something like an inverse cube. So, there’s usually not much point having a mode between 50% and 100% power.
For example, let’s say it puts out 1000 lumens and does 50 kcd lux. Here are the resulting levels in more detail:
0.1% power: 1 lm, throws 14 m, brightness 10/100
1% power: 10 lm, throws 45 m, brightness 21/100
10% power: 100 lm, throws 141 m, brightness 46/100
35% power: 350 lm, throws 264 m, brightness 70/100
100% power: 1000 lm, throws 447 m, brightness 100/100
So, to a human eye, the 35% level actually looks like it’s 70% as bright as the 100% level, and it throws 59% as far. Does the mode spacing make more sense now?
I had to take a few hours to get some work done and I have more to do but I’ll try to pop in here and there.
Thank you ToyKeeper for popping in to answer the questions that only you can. I’m absolutely thrilled with what you created for Convoy within the constraints of the current hardware.
As for the questions about modes between 50% and 100%, as I think a few others have mentioned already they simply don’t make much sense in application.
Sure it sounds great on paper but when you actually see the difference between 50% and 100% it’s not what you would expect. The visual or perceived difference between 50% and 100% is much closer to 10% than the 50% you’d expect to see. Light output just doesn’t work with standard mathematics where 5+5=10. In the lumen world 5+5=maybe 7?
I may be using a very wrong analogy but hopefully some are getting where I’m going. Others here can explain this way better than I can. It was ToyKeeper and Dale that showed me what I didn’t know about this topic. Truly proper mode spacing is wonderful. I’m not going to embarrass myself by trying to further explain what I only partially understand.
I do believe I have a fairly good grasp on what the masses want though and I’m doing my best to translate that into flashlight reality through Convoy with plenty of help from my friends here at BLF.
Oh and since TK threw the “Jared Stinks” suggestion out there (yes, it was my own suggestion) I’ll throw in my own suggestions.
“Convoy ToyKit”
“ToyKit”
“Convoy Kitchen”
I also see now that while I was trying to explain the 50%/100% thing and doing a bad job of it ToyKeeper came in and explained it beautifully. Bravo once again. :+1:
Thank you so much for taking the time to explain this!
To answer your question, yes it makes a lot of sense now. It is the first time I have really even halfway understood it.
Thank you again.
(You too Tom E…. …)
