I had to take a few hours to get some work done and I have more to do but I’ll try to pop in here and there.
Thank you ToyKeeper for popping in to answer the questions that only you can. I’m absolutely thrilled with what you created for Convoy within the constraints of the current hardware.
As for the questions about modes between 50% and 100%, as I think a few others have mentioned already they simply don’t make much sense in application.
Sure it sounds great on paper but when you actually see the difference between 50% and 100% it’s not what you would expect. The visual or perceived difference between 50% and 100% is much closer to 10% than the 50% you’d expect to see. Light output just doesn’t work with standard mathematics where 5+5=10. In the lumen world 5+5=maybe 7?
I may be using a very wrong analogy but hopefully some are getting where I’m going. Others here can explain this way better than I can. It was ToyKeeper and Dale that showed me what I didn’t know about this topic. Truly proper mode spacing is wonderful. I’m not going to embarrass myself by trying to further explain what I only partially understand.
I do believe I have a fairly good grasp on what the masses want though and I’m doing my best to translate that into flashlight reality through Convoy with plenty of help from my friends here at BLF.
