Just reflowed a 17mm with the 85. The MCU pin pads are actually quite wide, wider than needed for a 13A, but the 85 pins barely touch the pads, so I bend in one side, maybe slight bend in on the other. Here's how it came out, all buzzed out so no shorts or problems, but not tested yet:
Not sure what light I'll put it in yet, but should do well in a piggyback mount. The PCB is a thin one, 2oz, as I ordered from OSHPark.
Correct, the 17mm has the normal 150 mil SOIC8 pads as there is simply no room for the 209mil pads. The 209mil pads start on the 20mm boards and everything on up.
I tried fitting it on the 17mm but it just wasn’t happening.
Now that the weather finally cooled down I am able to get some work done again. (Thats Texas for ya, 83 LOW temp one day and 70’s HIGH the next) With no AC, the weather is what temp the house is lol.
I got a triple 219c S2+ built today. It works great. I replaced a prior attempt to build this light with a tripledown but every time it tried to engage the FET it would shut off, voltage spike I am sure due to the 17A current draw.
The new layout from DEL works just as it should the new Avenger triggers the FET without a hitch. Pulls ~17A and is making just under 3000 lumens.
Interestingly, it was pulling around ~16A previously with an FET+1 driver but only making around ~2400 lumens. The difference is that I machined out the bezel to clear the TIR reflectors and not cut off the outside edge of them. Apparently that is worth ~500 lumens. I have another XP-L Hi S2 that I will be doing the same thing to, I am interested to see if it sees the same results.
Yeah, I was impressed considering it is using 219c’s (and not the 320 binned ones that RMM sells now, the older 280 bin ones). Good tint and a floody but usable beam.
It really shocked me the difference that machining the bezel made, I figured it would hardly be noticeable but 500+ lumens (think it was closer to 2300 lumens before mods) says it made a difference for sure.
I am curious to see what the XP-L version with the same treatment does, I will have to get some better before numbers on this one. Also makes me think about what I could do with the 320 bin 219c’s I have here or even the XG-G3’s.
Yeah, I noticed the 0805 components, tight fit for sure but it does seem to fit. The 0603 components look a lot nicer and they are not nearly as crowded but for those that already have 0805 it is nice to not have to buy all new parts just to try these. With the way we keep adding things to drivers I have a feeling that 0603 will be the new standard size.
We should be able to drop C2. I think DEL's last thoughts seems less emphasis to need it. The 4.7 ohm resistor made the big difference, think he said it kind of made the C2 cap obsolete.
I saw that post although I would like to hear his direct thoughts on a custom driver such as this. I think the post you are referring to was directed at someone hacking together some kind of franken driver. Last I saw him say about a purposes built driver was C2 was very important?
I have one of these built now and running modified bistro tripledown. One question I have always had: why do we shut off channel one and two and only use the fet for the highest mode? Wouldn’t more channels open mean less resistance and more power to the led? I’m sure it doesn’t otherwise we would be doing it, but anyone know the reason?
I would love to have Narsil on my to be modded Courui with planned SST 90.
And well I prefer a driver that fits nice in rge light instead of using the default driver just for let power go through, I have the idea that a neatly fitting driver can pass heat of the components to the housing and is thus better.
Anything is possible! Just an FYI: Texas_Ace has made his Diptrace files accessible to us. You could actually download one and expand it to any size you want! Not saying he won’t do it for you. (That’s for him to decide)
Yeah, that’s what I thought, too. I followed a tutorial for Eagle and realized it wasn’t really all that hard. You can get Diptrace for free and watch a couple Youtube videos, and surely you can at least learn enough to extend the outer boundary of the driver a bit. You don’t even have to move any of the components! Come on! I tried it, you should too! :partying_face:
As for basic soldering, I’m beginning to think I’ll never get it right. But, with tips I picked up here (search bar helps) and a little practice, I can at least get stuff together usually.
Like was said the source files for all the drivers are included in the OSHpark links for anyone that wants to custom build a driver.
That said I have been debating making one of these for my own DO1. It will need a bit of custom work for the DO1 to clear the battery ring but that should not be too much trouble. Might move the 7135’s to the top side since there is a lot of extra room.
I am waiting to see what happens with Narsil and the R1/R2 before I make any further changes to the drivers. if we can ditch the voltage divider then I will do that on the drivers along with a few other changes.
It would allow for a 3rd 7135 channel in theory as well, which would be nice, or it could be used for an indicator LED. Been thinking about ways to make it optional on the drivers with a resistor if that comes to pass.
I also want to get the 2s/4s SRK/Q8 driver setup as well, in fact I could just shrink the Q8 design once I have it for the DO1 come to think of it.
So basically, yeah I bet I will make a driver for the DO1 at some point after I get the Q8 and other drivers done.
If anyone else have a special sized driver they need/want/know about, please do post here. I really am wanting to create a lineup of drivers to come everything in a single design. Standardization is good.
