XHP70 shaving…. IF you choose to shave the dome, make absolutely sure the surface you shave and any and all debri are clean clear or else you will have burn down, (debri) which will burn the emitter surface and smoke the reflector, causing a cloudy effect or possible emitter failure! I would leave it up to the end user to perform this at his or her want or need!
I hope turbo on this light can be memorized for quick access one click turbo.
Since this dont seem like it will compete with the tn42 or the k70, I would think this light would be better with xhp70 thrower.
More lumens than those other two!
This too looks very interesting
and I forgot: welcome to BLF!
I think it is very cool you engage with us and show not even finished lights. Also SMO reflectors siilnce that is the Nr 2 question for a XHP light here so it seems.
Yeah you made a heck of an entry, very cool to see this! Thanks.
Very true, just the other night we were exploring a creek after dark and playing with a hefty selection of lights.
An interesting comparison was the L6 vs S70. While they are virtually the same in lumens (S70 is slightly higher actually) and Kcd. When tested in the real world the S70 would throw a good ways but everything was washer out and at the far reaches of throw it was very hard to make out any details, you could just tell where the shore was and that was about it.
The L6 on the other hand was not even a high CRI, just a higher CRI and warmer 3A tint. At the same distance you could see the bushes, the rocks and the water quite easily. Even I was surprised how much of a difference it made with just a slightly warmer LED. My current king thrower is a DO1 with a ~5A XP-L high and it is amazing how well it cuts through the night and how clearly you can see what you are looking at compared to my other 1A tint throwers.
I am now on a high CRI kick and planning on swapping most of my lights over to them as soon as I find a good source.
Wow, can’t wait for this to hit the streets! I hope it has a reasonable price tag and that it comes in with an option for something in the 4500k tint range. I suspect in the real world a SMO reflector would work great, who wall hunts with a light like this???
My D01 is fairly warm, de-domed XM-L2 and it really has good target definition and color rendition compared to other throwers that I own. I would guess it to be somewhere around 4500k, started as a 0D.
