Well, looking for a good budget thrower. I see the Sky Ray STL-V2 is ~$55 with the Fandyfire STL-V6 ~$45. I am also looking at the Ultrafire HD2010 since it is 26650 and smaller. Overall I know the STL-V2 is one of the best but I don't know if there's anything better out there for about the same price or less, so let's cap this at $60 for the light. Any suggestions will be looked at.
i 2 would like 2 find a decent thrower/light sabre since i seem 2 have a serious problem with floody lights. it seems 2 me that u buy a flash light to reach out and touch some one/thing not light a room with it,
The Marsfire W-C88 I just got is a clone of the STL-V2/V6 and the reflectors are nearly identical (exact same depth but 0.5mm smaller ID). Need a new driver to bump up output as it's driven very mildly but if done should match the Skyray & FF rather easily. I only paid $23 for mine but good luck on getting that price again for a while.
By the looks of it, you are targeting XML throw as opposed to XRE throw... BIG beam versus skinny pencil beam. An XRE thrower in this price range will significantly out-throw any of the current XML designs... FYI.
45K lux seems to be the ceiling right now for XML throw in this price range. At your $60 ceiling most SST50/90 lights are out of reach, and none of them will have higher Lux than the comparably priced XML designs you are targeting. So thats right where the STL-V2, Fandy-V6 and Ultra-HD2010 are all at. All 3 lights push a T6 at ~2.7-3Amps, so they are all in the same Lumen ballpark. Their reflector geometry is nearly identical, so thats why they are all around 45K, and hence throw near-equal to each other. A stock HD2010 at ~40K is the lowest of the three, but unlike the others it can be easily modded to take a 7135 driver, for better regulation and a steady ~3-3.5A to the LED.
Theres just no one making bigger XML reflectors and pushing the LED at ~3A... in this price range.
This light here has the biggest XML reflector I am aware of... but its only pushing a T6 with 2A. BLF-er Pok measured it at 37K lux. So at 2A & 37K its not too far behind a stock HD2010, so that just shows how much more tightly its 75mm reflector is concentrating the beam. I think for ~$50 someone (ultrafire, sky-ray...etc) can easily make this light in a 1-26650 form and push the XML at ~3.5A.. that would sell like crazy and dominate XML thrower-land. Although with a beam that tight and concentrated... you might be starting to approach XRE pencil-beam territory, and you're kind of back to square-1.
Pok was able to mod it up to ~75K lux with 3.6A to the LED. But again, thats going to be over your $60 ceiling.
No... Given the smooth-flooding, semi-sphere beam pattern of most LEDs, A high lux thrower requires a large reflector dish. It makes sense when you think about what a reflector does. It collects the side emitted lumens from the LED dome, and reflects them forward in a concentrated beam pattern. The bigger the reflector dish, the more lumens it will "touch", regather and reflect.
Multiple cells aren't necessary to push an XML to its I limits. XML Vf is low enough (even at higher drive currents) to very closely match Vbatt(nom) from a single healthy 4.2V Lithium cell.
True, except “no” for large reflectors, and “yes” for multi bats. The HD2010 is a single cell but has a large reflector. You can also go with aspheric vs reflectored if you need a smaller head.
Something I have always wondered... Will your garden variety DX/KD ($8-9) ~50mm aspheric lens have a higher lux than a 50mm "throw" reflector from an STL-V2, V6 or HD2010?... so we're talking about peak lux value in the spot-beam. Keeping apples-apples, lets say were talking about XML designs at ~3A.
I don't own any of these lights so I can't comment on how hard they are driven or how well they throw. At one time, the X9 was supposed to be the king of the single-cell XM-L throwers IIRC...
Ok, HD2010 or STL, either one? I am leaning HD2010 for form factor and it's just a good looking light, just want to make sure that it throws just as well as the STLs.
