Hi, I need recommendations for a holster that will be best fit for UltraFire WF-501B!
Select from the following: first, second, third and fourth.
Thanks
Thanks
The 501b is 132.23 mm x 31mm the holsters you listed are either too short or to wide. Height is right on # 4, but the pocket is too wide 31mm vs 55.
Unless you need that exact style or the button ,the Ultrafire #119 is a perfect fit. Inexpensive, Readily available, and as tough as they get. I've had mine for over four years and it still is in great shape.
less than $ 2.00 shipped from BuyinCoins to name only one place.
the Ultrafire C8 holster from Manafont works pretty good with a Solarforce L2 that i have.
http://www.manafont.com/product_info.php/ultrafire-flashlight-holster-for-c8-p-7510
This is what I use for my UF WF-501B: http://www.dealextreme.com/p/ultrafire-nylon-camouflaged-flashlight-holster-mid-29355 It also fits my SF L2. The sides have garters so your light won't fall off even if the flap is open. It only costs $1.99. Too bad I couldn't get a black one.
I noticed that the measurements of thous 4 models I mentioned are a bit inadequate but was confused because actual place for flashlight is smaller than holster in general and they all look nice and robust/steady almost like they can't be bent easily...
I guess I will have to settle with the classical one like lyonn suggested...
Thanks to all for recommendations.
P.S. This concept is also interesting :)
