This is a lot like my D06, but smaller, lighter, knurled and probably floodier. Those are all improvements (for my purposes…probably not as good for actual divers) but unfortunately I doubt it has as much output (2.45A for the D06).
It sure would be good if communications weren’t so limited. We shouldn’t have to guess what a light that’s for sale does
Most dive lights with a magnetic control ring would be using Hall Effect sensors for on/off and output level changes so that there was no actual penetration of the body for water to leak into.
If it wasn’t a dive light mechanical switches are often used for on/off with the output levels controlled by an electric switch so there is no parasitic drain.
In this case the on/off must be magnetic as well. Buttons aren’t usually used on dive lights as water pressure would either keep them from coming on (reverse clicky) or from turning off (forward clicky) and they would leak at a certain point anyway. A magnetic button works however.
So, who knows what is the actual case with this light but the seller should be telling us
LED: T6
Color BIN: White
Total Emitters: 1
Battery Configurations: 1 x 18650 rechargeable battery (not included)
Switch: Sliding at its head
Modes: 3
Mode Arrangement: Hi > Mid > Lo
Lens: Coated Glass Lens
Reflector: Aluminum Smooth/SMO Reflector
Carrying Strap Included
I found w/ the d06, having just he right amount of lube on the switch is helpful. ie too much and is slides way too easy, to little and you can’t get a specific level because it won’t move then jumps when you finally push hard enough.
