At that price you could get a XTAR TZ50 if you want HA and a bit more compactness (dual and single 18650 option) and the SST-50. Its a perfect olight clone. However it is driven a bit conservatively and does about 617 Lumen in dual 18650 (the drain is around 2,6A at tailcap).
Otherwise it would be best if we knew what are you looking for?
Very high lumen count and very thrower don't go really hand in hand (in reasonable price range). A good thrower with SST-50 can be quite expensive and not a lot throwy...
The lumen claims are ludicrous for an SST-50. You'd need an SST-90 driven at 10 or so amps to get that sort of output. With luck, an SST-50 might be a third of that. Now that the XM-L has arrived I can't see the SST-50 being on the market much longer.
Indeed, also fueling the SST's at full potential with few 18650 can be potentially unsafe. Mayn underdirve those SST's . Reason being, cheaper drivers, heatsinking problems, cell requirement, and maybe safety concern along with the ability of claiming better runtime.
Long live XM-L!
Dolphin, i would advise you to reconsider your options. You can't have a very bright and very thrower light for cheap. Going into HID territory that changes but so does the expenses... radically...
If a thrower you want, the MRV is quite good and cheap. Just recieved mine and im impressed. There is room for tweaking if you want. That kind of light would go up to 350lumens (guesstimate) if overdriven hard and with a very good r2 in it.
But all depends what you would need the light for and how many lumens you want, althrough for throwers it may be best to look at lux at a defined distance perhaps.
Tell us more, we might help you better.
If you want something like this:
Well... that is in X000USD range, if i recall right around 5000usd... and it is not even led... (HID)
I would love to get one of these just for a nice looking host, but it'd have to come cheap. Anyone here got one to get rid of? I don't care if it doesn't work electrically but has to be a clean, non-beater host.
still love my POB HID very heavy unpractical but pretty cheap and a crazzzy trower
I also were thinking of buying a good double battery body, adding a driver and an XML to build my own big XML light, but then the total expense reached almost a $100 and I ordered Fenix TK35 instead :)
Yes the TK35 is good light but it`s a little overpriced in my opinion ! For more about 20-40 $ you can get EagleTac M3C4 XM-L , Olight M3X , Trunite Catapult XM-L or JetBeam M1xm ...
I googled for all those mentioned but i cannot unglue my eyes off the fenix tk35. Never liked much the rest. Actually is the only repurable brand name light that makes me want to spend the money on.
Too bad there is no clone of it yet in any form even in DIY parts to build from scratch which would be awesome.
I found one (TK35 I mean) for $100 at Hkequipment BTW. I just made an offer to an EBay sale, and they accepted it. There I were owing a $100 in the morning :)
Thanks a lot. My wife usually tells me to get the best one at first so that I don't pay much to find the way up. She usually is right like now, I've spent more than $500 to flashlights and have only one Fenix :)
There are advantages to not having a wife. My assistant never complains as long as I feed her and take her for walks every day. But she can't read, or write, or speak which helps a lot.
The color tint is very good. I expected to be more bluish. But the light is neutral white. It is under these 6000K maybe about 4500-5000K. It`s very similar to this of the original SST-50 LED. The beam spot is much more concentrated !
The lumens are clearly visible more than before ! The throw is definitely bigger probably 30-40%. I used the original 3-mode driver.The current that provides the driver is ~4A@3,45v at the LED. Its efficiency was about 80% with the SST-50 LED and it`s about 90% with the XM-L LED.
