18500 battery
11 posts / 0 new
adyscarborough
adyscarborough's picture
Last seen: 5 years 5 months ago
18500 battery
hi, does anyone know anywhere i can get some 18500 batteries in the uk??? iv looked at a few sites and i dont trust ebay to get quality batteries. would be gratefull of some help please Smile
CarpentryHero
CarpentryHero's picture
Last seen: 1 week 4 days ago
Dealers corner, AW ships international for affordable.
http://www.cpfmarketplace.com/mp/showthread.php?230876-AW-s-LiIon-Batter...
Great batteries since oveready.com doesnt sell international anymore
I’m glad I’m not the only flashlight collector out there, I was beginning to think I was strange.
My name is Kendall and I’m a Flashaholic from western Canada
adyscarborough
thanks, think i may have to try two in my olight m3x as im still having problems with the extension tube Sad
CarpentryHero
Hope it works, does your extension tube not thread up?
adyscarborough
when i run the m3x on 2 18650 cells i have to unscrew the extension tube a few mm and tighten the pocket clip retaining ring back to it to lock it there… if i dont do this and just tighten the extension tube as you would think straight onto the lights body the light starts to go on and off at random in use as if it has a loose connection. im thinking the 18650s may be too long as it works fine all tightened up on primarys which are a quite a bit shorter than the two 18650s.
CarpentryHero
Do you have any unprotected cells ? They might work
adyscarborough
no i dont have any. iv actually emailed the supplier of the light and he says to send it back for testing…. if they come up with ‘its fine’ and send it back though i will have to try 2 18500 or 3 rcr123 in it….. im not even sure if it will run these. hoping its a problem with the light and i get a repair or replacement to be honest.
CarpentryHero
The Olight peeps are pretty solid, they’ll probably fix it for yah. Might just be the pill needs to be tightened in or maybe the extender was just a little off spec when machined. I don’t own any but if I had more money I would Smile
adyscarborough
im not having much luck with my lights at all at the minute….i also got a keygos ke -5 at the weekend which cant be putting out more than 100 lumens…. iv contacted keygos but they havnt even bothered to get back in touch….
CarpentryHero
Is that the diving light? I have the M10 and I needed to clean the contacts on the hea and then loosen and re tighten the head onto the body a few times cause mine was fluctuating, does anything appear loose?
pounder
pounder's picture
Last seen: 2 years 10 months ago
the trustfire grey 18500’s might be decent..I have some 16340 grey’s and they’re good..probably 1200 mah or so for the 18500’s..I was thinking of getting some for my uf-v2..
