MRV q5 multimode to single mode modifiction help
3 posts / 0 new
Budgeteer
Budgeteer's picture
Last seen: 6 years 1 week ago
I have to change the stock MRV from 5 mode to single mode. Any easy way to mantain regulation of the present driver?
A also happen to have a:
http://www.dealextreme.com/details.dx/sku.26110
Extracted from the DX R2 dropin...
By reading the forums it would put the Q5 at 1,2A... Should i be worried? Q5 should be driven at 1A max.
Heatsinking of the MRV should be fairly good...
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
Budgeteer
Budgeteer's picture
Nevermind, i just swapped the driver and is pulling 1,12A at tailcap. Due to circuit loss i believe im not drawing much over the specs if at all.
If someone is curious, the manafont mousetail (momentary switch) without the endcap version fits the torch, not perfectly but good enough.
FlashPilot
FlashPilot's picture
Last seen: 15 hours 38 min ago
I run my MRV @ 1.6A (tailcap reading). I think the XRE will hold up @ 1.9A if well heat sinked. Some are running them @ 2.0A and 2.1A. Someone on CPF did a graph that plotted current vs lumens a few years ago and there wasnt a whole lot to be gained above 1.6A as I recall.
