Looking to take some measurements of current draw in my lights and am looking for a suggestion on a decent, under $30ish DMM available from a local store. Do they exist? I have access to lowes, menards, true value, radio shack, home depot and harbor freight.
gentlemen, excellent! Can both models stock leads handle measuring DC amps w/ out modifcation? seems some DMMs need upgraded test wires to keep resistance at bay…
Even more expensive DMM’s can use better wire leads if you’re measuring over 3 amps or so. It’s pretty easy to just make leads out of thicker wire and banana plugs.
founda unit at Home Depot that does what I need for $20. I was even more psyched when I got it home and found it measured voltage as accurately as my lipo analyses tools and my ichargers. I had been using a DMM that was reading like 4.08V for a freshly charged cell, where my specialised volage checker I use w/ my RC Lipos was reading 4.12.
I did some tail cap measurements by touching the + end to the neg lion battery endand then touching the neg lead to the de-anodized threads on the tail end of the light. I was able to cycle through modes by quickly removing and touching the threads again. On a UF 502B w/ underdriven XM-L of a supposed T6 bin, I got 1.75A on a 3.96V Blue UF 3000mah that came w/ the light. W a new TrustFire 2400 black and red protected, I got 2.1A.
