Hello everyone!
As mentioned in Mr. Admin's excellent review I was a little bit concerned about the heat sinking in this light. Running on Hi it did not get noticeably warm which I thought is not ideal and looking inside the head there was no real thermal path. With a 14500 tailcap draw in my sample was 0,44 A. I have no clue if this is enough to cause a thermal issue for the LED (comments welcome) but I like my lights to last, so I thought better safe than sorry. The solution was straight and simple, here we go:
Inside the head embedded in the omnipresent white silicone is a heatsink-like object.
Extracted. Not the most beautiful example of craftmanship. It did not make any contact to the body either.
There's not much room inside the head, but still room for improvement.
I simply filed a piece of aluminium to an appropriate size. The side facing the LED is 6x6 mm, length is 10,5 mm. The end facing the occiput of the light is slightly curved to match the inner contour of the body.
After tapering the side facing the LED a bit to avoid contact with the LED leads and fine adjusting the length I could insert the new heatsink. I thought I would fixate it with thermal adhesive after the fitting, but it has such a tight fit that I could not extract it again, so I left it.
Before reassembling the switch I placed a piece of adhesive tape on top of the heatsink to avoid contact issues (the original soldering points of the leads to the switch are quite near the centre).
Now, I still don't know if this was necessary at all, but running on Hi the head of the light is now getting more than hand warm after a few minutes and I take it as a good sign having done this. :beer:
