I’m pretty new here, but in by no means am I new to batteries and battery technology. I’ve been heavy into RC helicopters for about 3 years and currently manage several sets of LiPo batteries (some costing upwards of $200 for 1 flight pack).
In my recent endeavor into flashlights, I’ve been happy to find that my ichargers have a LiIon charging mode that works well. What I have not found is a solution for charging multiple LiIon cells quickly.
In the RC world, it’s quite common to parallel charge upwards of 6 6s batteries at a time. I frequently charge batteries at up to 30A @24V.
What I want to know, is if there is any interest in a docking station where one could charge, say, 4 18650 or 4X 26650 cells in parallel at a time? I have a few design ideas in my head and a very good friend w/ a plastic molding business. I want to design a docking station that would accept multiple cells and then just hook up to a hobby grade charger via banana plugs. I can’t find this product on the market and that is why I ask. If you have questions about charging cells in parallel, please ask as it is a safe way to charge up multiple cells at once.
I also have an iCharger. So far I balance-charge up to 3 18650 cells only (in series) because I only have 3S balancing wire connectors (taken from a lipo 3S batt pack) that you plug at the balance-mode chargers side. I don’t have a good docking station for either series or parallel charging connection. I use magnets. I’m also interested in what you’re looking for.
The best way to accommodate different capacity cells is to parallel charge and in fact, it’s safer to parallel charge vs charge in series. If you have a 500 and a 5000mah cell in parallel, as long as the voltages are close to the same when inserting into a docking station, then all is good. The larger cell will receive most of the current while the small cell receives less current and the voltages should stay relatively the same throughout the charging process.
My idea for a solution would be a plastic molded accessory w/ tabs and springs to accept 4 cells. These 4 cell charging stations could even be linked in parallel and you could theoretically charge as many cells at a time as you want, as long as they are all 3.7V LiOn cells. One station would attach through banana plugs to the charger and voila!
This would be a super cheap charging dock for charging multiple LiOn cells in parallel. No screens, no high cost, nothing like that. Just a way to charge multiple cells at once.
