I was searching around on hkequipment.net and i saw an C8 with sst-90 here
and a& C8 with sst-50 here
I already ha a C8 with xml-t6, so what do you think guys, is it worth the money or not, because i think it’s underdriven?
and should it be more lumens than my xm-l t6 C8?
but i have a C8 xml-t6 from hkequipment.nethere
and there also stands working current 400-650mA but this light is really a beast so maybe the info on the website isn’t correct?
The bin number is very important when considering buying a luminous Sst emitter.
A good Sst 50 is almost as bright as an XML at the same amperage, and only when driven up at 5 amps does it match the XML at 4 amps.
Sst50 is slightly floodier.
Sst90 is much floodier than the XML, with the right heatsinc and driven hard enough (9-13 amps) it’s capable of 1600-2200 lumens.
For something with a similar reflector. I have the FourSevens Maelstrom S12, it has a similar reflector size to your C8 but the hotspot would be three times larger at 30-40 feet, and only 600-700 lumens.
For an sst90 to outperform your XML, expect it to cost $120+ and be of a fair size.
Or it’ll be floody.
I also own ElectroLumens BigBruiser, it runs an sst90 full out as it has an amazing heatsinc but it’s all flood. (I like floody lights ALOT)
