Review: The little red AA host (fron CNQ) White wall shots added.
36 posts / 0 new
MRsDNF
MRsDNF's picture
Last seen: 16 hours 1 min ago
apt323 wrote:
MRsDNF Well your review made me order this host and I received it yesterday. I have a question though about the assembly of the switch. Do you have to solder the tabs of the switch to the blue disc on the edges where the gold colored parts are? Hopefully that made some sense. Then the retaining ring makes contact with the other side of the blue disc for for the switch to work? I have never built a switch before. Thanks
Yes you are correct. The retainer for the switch connects to the tail cap of the torch for the earth. In the top picture you can see the trace that runs from the centre to the outside. When the switch is activated it puts the negative from one side of the switch through to the other side to the battery board and then through the flashlight body. I hope that makes sense. The only problem I had though was the switch with mine was faulty. I would also advice to solder the spring on the opposite side first to keep as much heat as possible away from the switch as possible. Good luck.
apt323
apt323's picture
Last seen: 1 week 3 days ago
Ok thank you for the information.
Now to just decide what driver and what led? Maybe a U3 with with custom driver from E1320 or i have a couple of aa drivers from dx? Hhhhhhhmmmmmm
MRsDNF
MRsDNF's picture
apt323 wrote:
Ok thank you for the information. Now to just decide what driver and what led? Maybe a U3 with with custom driver from E1320 or i have a couple of aa drivers from dx? Hhhhhhhmmmmmm
The reflector will not take a XM-L U3 LED as the hole size for the led is to small.  I would suggest an XP-G or XP-G2. What are the AA drivers you have?
Match
Match's picture
Last seen: 3 years 10 months ago
Very nice review/build - thank you for sharing.  I've looked at this little host a few times while going through CNQG's site, along with their SS hosts.  Might be time to order a few.
apt323
apt323's picture
.MRsDNF
I should OPEN MOUTH INSERT FOOT…….. :~
I guess I was thinking of the F20’s I got in and they are big enough to handle the xml. I fill like deleting the post now….. Sad
Will let you know what drivers I got they are at home and Im at work right now.
