I’m really keen to get into doing some custom modding, but I know I need to learn more first. So I’m hoping you guys can help me out a little?
I’ve seen this LED star on DX:
XM-LT60 1000LM LED White Light Emitter with 18mm Base(2.9~3.5V)
Linky
I’ve got a couple of questions:
1. It says 2.9-3.5v - I presume this means what the driver would put out rather than the cells in use? As 3.5v isn’t high enough for even a single ICR Li-ion? I also presume that should you want to direct drive the LED (not that I do) that you could only do so on a max of 3.5v?
2. In terms of construction, is it really as simple as mount star on a heatsink, solder positive and negative wires from the driver to the star and connect the positive/negative input of the driver to the power source? I think it’s right, but it just sounds a little too simple…
3. Is this LED star recommended/worth it? The DX reviews seem to suggest so, but I’m not sure how much faith I put in them.
4. Driver - What would be a good driver (DX or other) to go with this LED? I’ve had a look at the drivers on DX but find I’m a little perplexed by the choice. Any guidance you can offer would be greatly appreciated.
Thanks.
