Driver for the MT-G2
108 posts / 0 new
nitro
nitro's picture
Last seen: 2 years 9 months ago
Hey guys I just ordered 2 MT-G2 LEDs and need some input on what driver might work the best with the led ??
zeremefico
zeremefico's picture
Last seen: 11 min 16 sec ago
7135×6 for best performance.
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Match
Match's picture
Last seen: 4 years 6 months ago
zeremefico wrote:
7135x6 for best performance.
That would be good for the xp-g2, but not the MT-G2.  If you ordered the 6v version, I'd look into one of the multi-xml drivers as a good start.  After I finish up some current projects, I'll get started on a build with this emitter and keep you posted.
nitro
nitro's picture
Like a 3amp driver
zeremefico
Sorry, I really want a xp-g2 and I missread that.
My YouTube channel
K40M F16
Pok
Pok's picture
NightCrawl
Wait for PPTKs new driver. Wink
nitro
nitro's picture
would a H6CC Version 1.0 driver work i got one here
and this one
http://www.kaidomain.com/product/details.S006371
JohnnyMac
JohnnyMac's picture
I'd recommend a driver meant for triple XM-L in series.  This will put out 9-10v and should be good for a 9v MT-G2.  The only problem is you may want more than just 3A (I know I would).  Problem with this is the 9v MT-G2 is rated for max of 2A.  Your best bet is to hang on, like NightCrawl said, for PilotPTK's new MT-G2 driver I heard he's working on.
Another option for a 6v MT-G2 is direct drive from 2 Li-Ion cells with a resistor mod to drop the current from 8.4v to the low 6V range.
nitro
nitro's picture
Ill hold on and wait for the PilotPTK’s driver so I don’t blow the led lol
Match
Match's picture
Just in case anyone is looking at this one, the 9 volt mt-g2 is only rated for a max of 2 amps, so a 3A driver would be overdriving it by ~50% already.  Heck, the 36v one is only rated at 500ma.
JohnnyMac
JohnnyMac's picture
Really???  I thought this monster had to be driven at well over 3A.  I guess I figured it was the same as the 6V model.  Good to know. Wink
DARCANGEL
DARCANGEL's picture
Last seen: 6 months 1 week ago
Cutter doesn't even have the 9v,just 6 or 36,this is going to be a real pain to find a driver for.Trial and error will be the way to find out what works best,I,m going to try a 5 amp sst-50 driver@8.4v with the 9v mtg and see what happens.Just have to wait for the 9v to be available.
ChiggerPepi
ChiggerPepi's picture
Last seen: 1 month 4 weeks ago
JohnnyMac wrote:
Match wrote:
JohnnyMac wrote:
I’d recommend a driver meant for triple XM-L in series.  This will put out 9-10v and should be good for a 9v MT-G2.  The only problem is you may want more than just 3A (I know I would).
I think you guys are forgetting the simple fact that measuring the approximate output of an LED by amperage alone isn’t entirely correct.
We can generally get away with it in this forum because normally all the LEDs we use operate at the same voltage, but these don’t.
Volts X Amps = Watts
So, for the MT-G2, it only makes sense that the three versions are as listed:
6V at 3A = 18 Watts
9V at 2A = 18 Watts
36V at .5A = 18 Watts
For an XML:
3.1V at 3A = 9.3 Watts
________________________
FYI, because I was curious, they list the MT-G2 maximum output:
1987 lumens at 18.5 Watts = 107.4 lumens per watt
And the XML maximum output:
1040 lumens at 10 Watts = 104 lumens per watt
So efficiency is pretty similar, it’s just capable of a much higher input, thus allowing far more output.
To me, this LED means we now have the capability of a much brighter flashlight in a single LED format. I’m excited.
Now we need a suitable driver.
Pok
Pok's picture
Yes, MT-G2 has more Lumen/Watt. but bad for brightness/die area.
So MT-G2 is suitable for Flooder flashlights.
I’m still waiting for mass SBT-70/SBT-140 or CREE round LED for make Thrower or Flood to Throw flashlight.
RaceR86
RaceR86's picture
Last seen: 4 years 8 months ago
Bumping this thread. Anyone have some good driver options now?
Group buy on MT-G2 going on here.
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
gords1001
gords1001's picture
Last seen: 2 years 4 months ago
I fitted this driver in my torchlite build, I get a 3a tailcap reading on two keygos 26650’s (not the best cells in the world) its comfortably bright on high and low is wickedly low considering.
pop over to the torchlite thread by edcplus ti see what we all tried out.
comfychair
comfychair's picture
Last seen: 4 years 5 months ago
Subscribing, cause all this driver stuff makes my head hurt.
Ramblings
Ramblings's picture
The ideal is, of course, always sold out here.
The overdriving one, is more expensive and needs substantial heatsinking, I would imagine.
You are the light of the world. Like a city on a hill, you cannot be hidden.
People do not light a lamp and then hide it away, instead they put it where it gives lig
Slim Pickens
Slim Pickens's picture
Last seen: 2 days 8 hours ago
FT has a 5 mode version:
http://www.fasttech.com/products/1612/10001998/1143104-2-3-lithium-5-mod...
LCK-LED has a similar/identical driver with just Hi/Med/Lo (also it is the same driver as KD’s “Super Output” buck driver)
http://www.lck-led.com/19mm-3000ma-driver-modes-p-501.html?cPath=135
I do wish FT would stock a 3 mode version.
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 10 months ago
b3flex for 3000mA
h6flex for up to 6600mA
Probably the best drivers out there.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
comfychair
3-3.5A is just not enough. And it's 3-mode! ...what? Stop looking at me like that...
ImA4Wheelr
Any buck driver rated for the voltage you will be supplying should work fine. The closer the supply voltage to the vf the better. The 6v mgt2 vf climbs as the current climbs. So more than 7v if going over 3 amps. I have used that cheap 3T6 from Manafont with great success. Drives around 4.5amps stock. That was with 2S 18650’s.
Right now, I’m using just straight 7135’s with manual switches to control current and have 6S nimh cells. So 7.2v total. The cells are 4/3AF’s. Works great.
comfychair
Old-Lumens wrote:
b3flex for 3000mA
Don't forget the HBFlex... the only 3-amp-capable boost driver I know of - but the low end of the input voltage range is too high for a single cell (too high for two cells, really, though you might be able to get by), which is a shame.
Does anybody know if the TaskLED drivers, specifically the H6Flex, can survive with LEDs in parallel? I know that's the 'wrong' way to do it, but it usually works fine in the non-theoretical real world.
mattthemuppet
the driver won’t care about the LEDs wired in parallel, although the risk of an imbalance in Vf and current draw between the paralleled LEDs increases with current I believe. That’s just theoretical though, I’ve no practical experience of it.
comfychair
So, how do you calculate total/individual amperage with LEDs in parallel run off a common output? For example if I used the H6Flex in the triple MTG2 build with 4S cells and LEDs in parallel, vs. the original plan which was HBFlex boost driver with 4S cells & series LEDs.
(numbers with the HB boost: cell voltage 12-16.8v in, total series Vf of ~18.9v; w/H6 buck: 12-16.8v in, parallel LED Vf of 6.3v)
MRsDNF
MRsDNF's picture
Last seen: 23 min 50 sec ago
I have no measurements at all as I have only just got my pill together with driver and led but can confirm that this driver will run the MTG-2 hooked up to a couple off trustfire 26650 at 3.8 volts with no load on them. The led is direct to copper and it is the quickest I have ever had a pill get hot. The mode changes still has that pause between them as reported elsewhere.
comfychair
Cells in series or parallel? I have one of those drivers on the way, too.
MRsDNF
MRsDNF's picture
Series.
comfychair
Crap! Sad Was hoping for some actual single cell boost action. Was it you or somebody else who reported that driver didn't like running off a single cell?
MRsDNF
MRsDNF's picture
comfychair wrote:
Crap! Sad Was hoping for some actual single cell boost action. Was it you or somebody else who reported that driver didn’t like running off a single cell?
I just tested with 2 and 3 cell and now you want 1 cell tested? Ok, you sorta asked nicely. Be back soon. It is cold out there. Wink
