Adapting 20mm driver pill to 17mm
22 posts / 0 new
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 4 months ago
I just got a UniqueFire UF-V3 and while it is an awesome little performer, it is way under driven (1.74A on high). Obviously I want to replace the driver but the pill in this light only takes 20mm drivers. This poses a problem as there are no 20mm drivers I know of that meet my needs. I first thought I could just place a 17mm driver inside behind the 20mm driver but the space inside the pill is only 4.5mm deep. Besides, being an all aluminum pill, soldering a good, dependable ground to the driver would be difficult. I brought out my bin of parts and figured a P60 pill might just fit inside of the original pill. I can work with that! Here is what I did…
Here you can see that a brass p60 pill will almost fit inside of the 20mm pill of the light. What we need to do is grind down the circumference of the brass pill a bit plus enlarge the inside diameter of the aluminum pill. Leave enough material so that they can be pressed/hammered together for a tight ground for the driver.
Here is a pic of the modded p60 pill compared to a stock version. I ground down the emitter side lip so that the brass pill will sit tight against the inside rear of the aluminum pill. I’ve also ground down the sides of the brass pill so that it can be pressed into the aluminum pill.
Using my rotary tool and cutting bit, I have cleaned up the inside of the pill and removed some of the inside wall to allow the brass p60 pill to be tightly press fitted.
A dab of fujik fills any air gaps between the top of the p60 pill and the back inside of the original pill.
Now that your brass insert is ground down and your pill opening is opened enough to allow a high pressure fit you can place the two in a vice and press seat the brass insert into the original pill. Optionally you can carefully tap them together using a block and hammer.
Onced pressed in by vice or hammered in with a block you will end up with an aluminum 20mm pill with a 17mm brass insert for your new driver that can easily be soldered to.
I’m quite sure this could be used in any light with a pill meant for a 20-21mm driver. Hope it helps some of you. Wink
Johnny
Itinifni
Itinifni's picture
Last seen: 1 day 16 hours ago
Great ideal Johnny, thanks for posting.
I remember a time, when I searched for lights to fit my needs. Now I search for needs to fit my lights.
Modig
Last seen: 6 years 7 months ago
So, where can i buy some p60 pills then?
gords1001
gords1001's picture
Last seen: 1 year 9 months ago
Nice one johnny, I’m planning on fitting my m10 driver in my uf-v3, but I might do this and throw a 3a driver in instead.
Blord
Blord's picture
Last seen: 4 years 4 months ago
I have a bag full of empty P60 pills. PM me if you want some.
Modig
Great, thanks!
JohnnyMac
JohnnyMac's picture
I get mine from CNQG for 50¢/piece in a 5-pack.
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 2 weeks ago
Easing the edge of the brass pill might allow it to press in without scraping burrs of Alu. Tighter fit with less pressure needed.
Scott
JohnnyMac
JohnnyMac's picture
the burs were only around the wire holes in the back of the emitter plate in the pill. They need to be removed for the face of the brass pill to sit flush against the emitter base of the aluminum pill. Both brass pill and inside walls of aluminum pill need to have material removed for them to fit together. It is extremely tight and had to be hammered in. Wink
djozz
djozz's picture
Last seen: 2 hours 7 min ago
ha, I like that, a bit of hardcore rough hobbying!
Pok
Pok's picture
Last seen: 8 months 1 day ago
Hill
Hill's picture
Last seen: 1 year 1 month ago
Great simple mod, thanks Johnny!
My lights here and here
apt323
apt323's picture
Nice job JM. Thanks for posting the information.
apt323
apt323's picture
I put in a nearly full P60 pill in the MXDL SA-16 today at work. This light has a pretty long spring so i though that is I moved the driver out a little then used a short spring it would be the same.
I used the belt sander at work and removed alot of the threads till it was close and used the press to push it in the pill section of the MXDL. Then heated both of them and flowed some solder in the gap so that I would know there would be a decent contact between aluminum and the brass.
Heres a few pics.
sorry pics were taken with Iphone
JohnnyMac
JohnnyMac's picture
Nice job!  Beer
apt323
apt323's picture
Thanks, thanks for the idea!
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
Good simple fix JM. Thanks for posting it!
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Tom E
Tom E's picture
Last seen: 53 min 58 sec ago
 Thank You, Thanks You JM. This is the solution I was looking for. I have a UF-V3 and 2 friends bought them as well. Also, I know there are at least a couple of more BLF'ers that are interested in having someone do this type of mod - Rusty Joe, ZW99GT. Gotta order those drop-in's and a few more drivers. I'm leaning towards the KD V2 at 3.04A, may be a little too much for this light because of the poor heat mgt, but the brass P60 insert will definitely help.
Tom E
Tom E's picture
JohnnyMac,
 Is this the same P60 -> http://www.cnqualitygoods.com/goods.php?id=1400 ?
 It says 26.5mm, and 5 for $3.50. I don't see anything smaller on CNQG. The specs are sparse to say the least, I assume the 26.5mm is the width, but it looks like the one you used is a smaller width?
JohnnyMac
JohnnyMac's picture
Tom E wrote:
JohnnyMac,
That is the exact one. The 26mm refers to the reflector size that will attach to the threaded portion when making a full p60 drop in. You only need the part you linked to. Smile
Tom E
Tom E's picture
JohnnyMac wrote:
Tom E wrote:
JohnnyMac,
Ok, thanks, just ordered, but from FancyFlashlights - order worked out cheaper w/free shipping/tracking, of course it came to $56 by the time I was done... Had to add some more U3 1C's ($7 is a good price, I paid $8.50 at I-O, but now down to $7 also), variety of parts/holsters, along with 2 of the 5 pieces of the P60 (10 total) to have plenty of spares.
Tom E
Tom E's picture
 Got the order in today... Got the brass pill pressed into the UF-V3 aluminun pill (used the dremel sanding attachment to do it all). Did it slightly different, left a 2mm lip above the brass star surface, so filled the 2mm gap with Fujik grease. I wanted the driver board to be mounted further back towards the battery - original spring is long, but will use a shorter one. The final assembly has a lot more mass/weight than the original - will go with a KD V2 8*7135 + 1, total of 3.42 amps. Extra mass should definitely help. Still debating if I should put in a U3 1C or leave the original U2... Dunno if it's worth it - probably not much difference...
