The seller wishes to earn more now that cells are somehow more recognized. Usd to buy packs of 5-6 at around 4usd each with shiiping. Would buy again if up to 5usd each.
If it helps, they held a bit more charge than XTAR 2400mAh which was tested somewhere a while ago (Might be Old review perhaps) and holds about 2400mAh. If my subjective opinion counts, these are far better than anything including shipping up to 6usd a piece. After that price point solarforce or XTAR seems the general consensus. I might be the only one on forum with XTAR cells experience however...
It sounds like there are those that have recently had mixed results with these cells, which is to bad. These have always outperformed any and all low priced cells for me. In comparison, the highmax have a distinct voltage sage that occurs just after startup, but they will also burn longer, albeit at a slightly lower contiguous output to the LED. It would be interesting to see a 3A discharge comparison between the two. I still look forward to the day that carbon nano tube technology becomes integrated into cheap LiCo cells... hopefully within the next decade.
I hear ya on IR of some of these cells. I feel regardless of capacity ratings and whatnot , Until we do tests on the Hi-max, xxFire, Solarforce ( new blue line) . They are what they are. I myself do not ATM have a load amount to really test this with two hands ( i have two hands).
Have been happy with Hi-Max and Solarforce batts at this point VS xxxFire brands.
Over the draw spcetrum The Hi-Max need to really get into the game. I like them, but lets see the lines :) Possibly even tag them as a well known cell :)
well most of my trustfires cant draw above 1.6 amps on a 2.8 amp shiningbeam regulator!
i had some that only could pull under .4 amps!
two did acceptable. one draws 2.69 and the other 2.56. considering its designed for 6V, not 4.2, ill take those two anyday.
the other 3 that are crap, are good enough for an aurora light that draws 1.4 amps (they pulll 1.3) from the same battery. (btw its a q5.... dont ask me why it draws so much!)
