stupid, simple, really quick question
13 posts / 0 new
sixfink
Last seen: 11 months 3 weeks ago
Accidentally, I had dropped one of my protected 16340s down the staircase, two and a half storys to be exact. The outer insulation/ shrink wrapping has been damaged slightly, and there is a tiny bit of deformation. Brand is solarforce, 880 mA. Still, it charged to 3.7 V with no apparent problems.
I have noticed when using those recs with my 4.2 - 7.4V rated (heck, with about any dropin, even the incandescent P60), it cuts out really quick. The light used to run for several minutes before it went dark, but that time has significantly decreased in the last days.
The flashlight will now cut out within seconds.
Uneven discharge has also been noticed (as of last night, when I finally found my misplaced voltmeter again).
No heat buildup, no hissing, no sparks, no fumes (yet!). total runtime of the 16340s was less than 15 minutes since I dropped one of them.
Sooo... just to clarify:
Are we all of one mind that I should properly dispose off those 16340s in question A.S.A.P. and not push my luck any further?
Simon
fishinfool
fishinfool's picture
Last seen: 8 months 1 week ago
I am not an expert whatsoever but if I were you, I would not take the chance.  Batteries can be replaced but fingers or a house is a different story.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
anduril
Last seen: 2 years 10 months ago
Trash. Even if only for the peace of mind.
old4570
Last seen: 1 month 2 days ago
Sounds like the cell has been damaged , I would part with it safely ...
RCR123A's are cheap enough ...
+ There are no stupid questions , only silly answer's
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Budgeteer
Budgeteer's picture
Last seen: 6 years 6 months ago
+1
Nothing to add.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
FlashPilot
FlashPilot's picture
Last seen: 13 hours 10 min ago
Please recycle this one and dont use it any more. You're quite possibly playing with a potential bomb.
Boaz
Boaz's picture
Last seen: 39 min 29 sec ago
Arrow Right Simple answer
kragmutt
Sixfink you still alive?? =O
jb1
Last seen: 3 years 6 months ago
Earth to sixfink. Come in sixfink. Over.
sixfink
Howdy back,
all is well, thank you. Sciatic nerve compression has kept me busy.
That 16340 in question has been discarded properly today, along with another pair of used CR123's showing erratic (fluctuating) voltage readings.
Taped up the contact terminals and brought them to the local battery receycling disposal when I was on my way to see the orthopedist.
By the way, I found some ludicrous videos on youtube. Hard to believe someone would really punch a lithium cell with a screwdriver, without gloves (and therefor presumably no other protection like a face shield and respirator). Hydrofluoric acid poisoning is mighty Eeep!, big time...!
Simon
kragmutt
sixfink wrote:
Howdy back,
Simon
Ouch. How does one get sciatic nerve compression? Hope things are ok.
cessnapilot
cessnapilot's picture
Last seen: 2 years 11 months ago
has anyone ever cut a lithium battery in half with a band saw?  what would happen?
Don
Don's picture
Smoke, flames, generally bad stuff. Liberating hydrogen fluoride indoors is generally reckoned to be a bad thing. Sure is for your lungs.
http://www.nerc.ac.uk/about/work/policy/safety/documents/guidance_lithiu...
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
