Tripods for flashlights
14 posts / 0 new
Haggai
Last seen: 15 hours 32 min ago
[maybe we need a flashlight-related gear forum? luxmeter/multimeter/tripods etc.]
I want a tripod head that can hold a flashlight.
The head's thread should fit a standard 1/4" tripod screw, like this one has: http://cgi.ebay.com/Mini-Metal-Tripod-Digital-Camera-Sony-Canon-Nikon-/190340154323?pt=LH_DefaultDomain_0&hash=item2c512843d3#ht_2879wt_905
There is this "complete" solution (too expensive, not versatile): http://www.dealextreme.com/p/swivel-flexible-legs-metal-tripod-for-flashlight-2-5cm-diameter-44497
There's this flimsy solution: http://www.dealextreme.com/p/universal-clamp-mount-for-tripods-holds-up-to-3-8cm-thick-objects-14150
And there are the bike flashlight holders, which I am not sure can be mounted on a tripod (but seem like they maybe do... dunno):
http://www.focalprice.com/LF659B/Adjustable_Bicycle_LED_Flashlight_Torch_Plastic_7_Mount_Holder_Clip_Black.html?SSAID=447047
http://www.dealextreme.com/p/universal-adjustable-bicycle-mount-for-flashlights-2cm-4cm-diameter-36095
What do you say?
Will the bike holders do the job?
Do you have any other suggestions?
mitro
I'm in pretty much the same boat. Well, I have a couple tripods I just need something secure to adapt them to hold my lights for testing.
Don
Don's picture
Last seen: 2 years 11 months ago
The one that looks like a microphone clamp
actually works well enough for up to single 18650 lights, the 2x18650s are a bit too heavy for it. I just need another more rigid tripod to hold the lights. The various little ones are basically useless for holding lights.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
mitro
Thanks for the info, Don.  That clamp looks fine for most of my uses, I just don't want to wait a month to get it. Smile I've had an Ultrapod II for many years and find it quite sturdy. Here it is holding quite a load.
Don
Don's picture
I'd try your local music gear shops for microphone holders - take a suitable light and see if they'll hold it stably. Probably won't be a huge amount more than DX prices.
Boaz
Boaz's picture
Last seen: 7 hours 10 min ago
big metal  clamp bend one leg in a vise drill hole ,add bolt , double nut and add to the tripod ,
OR
 make a small piece of wood to use in your quick release ,bolt it to your clamp and done .
OR
 2 clamps  &  2 big rubber bands
 rubber band the two together one up one down,, one left  the other right ,two rubberbands grabbing them in the middle and bang instant clamp up clamp down .Used on numbers of things including bikes ..I like them better than the 4 different  bike mounts i have bought  ..  this type of clamp  >>> http://www.harborfreight.com/1-inch-spring-clamp-67091.html
too easy
fishinfool
fishinfool's picture
Last seen: 8 months 2 days ago
Or get a couple of these really cheap mini tripods and put a small amount of silly putty on top.  After your done you can always play with the silly putty. Big Smile
http://www.youtube.com/watch?v=6LYkAUj7e6Y
How do you insert a video instead of just posting the link?
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Don
Don's picture
Try the second from last button on the right. And fiddle around a lot. Easier to post the link...
fishinfool
I'll give it a whirl.  Thanks Don.
I just tried several times and I give up.  You're right--posting a link is ALOT easier.
Vectrex
Vectrex's picture
Last seen: 1 month 1 week ago
embedded Youtube video test
Vectrex
Vectrex's picture
Takes about 10 seconds.
Go to Youtube -> embedded -> old code -> select size -> copy code
On BLF -> disable rich-text (under the window) ->  paste -> save -> bam Wink
fishinfool
Thanks Vectrex!  You're a friggin' genius!
Haggai
Ok, I went for the mini tripods + clamps from DX.
The clamps are cheaper in local stores (~1.7$ vs 2.7$@DX), but are not available in my area and shipping costs inside Israel are about 10$ Yell
And the mini tripods sell here for about 12$ Yell
So my purchase of 3 mini tripods + 2 clamps at DX saved me over 40$ !! Money mouth
Unbelievable.
Vectrex
Vectrex's picture
Don't say that too often, or I may start believing it. Wink
