U2 is marked in the Wiki as being the highest bin being produced. The U2's just came out and I don't know of anyone that has received one yet. The difference between a T6 and U2 won't be noticeable by eye since it is only one bin of difference, but should show up with a lux meter. I'm looking forward to neutral T5 XM-L's more than the U2's since I already have a couple of T6's.
There's no way to really prove KD is selling real U2 bin LED's, but I'll take their word for it. But don't believe the output claims: There is no way they are getting 1300 lumens.
Thanks for the replies. So, what's the battery life for say 1000 lumens T6 vs 1300 lumens U2 at max mode continuously using 3.7V 3000mah 18650 battery?
Just a sidetrack. Anyone uses UltraFire's 3.7V 4000mah 18650 battery? How's its performance over the 3.7v 3000mah?
Well, it won't put out 1300 lumens ever. It will put out about 7% more lumens than a T6. The good part is it will do that using exactly the same amount of power. It is just more efficient.
Did you notice that it's 9" in length? It is darn long as compared to normal 1x18650 flashlight of about 6" length. Could there be something inside that flashlight (a booster may be) that makes it the equivalent of a U2?
Thanks for the quick reply. One more question. Is the RQ 07 CREE XML-U2 in my first post link on KD worth buying? Even though it doesn't state its rated at 1300 lumens but on ebay its stated as 1000+ lumens. I suppose this flashlight ouputs more than the CREE XML-T6 1000 lumens flashlight, right?
Here's some info I copied from the DX forum. I believe these specs are from the manufacturer at the emitter. This aren't the actual O.T.F. lumens. For example, the Fenix TK35 has an actual output of 820 lumens but it's one of the better driven emitters. Someone with more knowledge will jump in with more realistic numbers. More like 600ish I think.
Ojgfdkpoijsazvknzskdfz! I highly doubt that KD has U2's- even Fenix has not gotten them yet! They expect they're going to get them mid april, and they should have higher priority over KD, right? I'm going to say that max OTF of an XML at KD is gonna be around 800.
I wouldn't say that's for sure... KD had T6s on the market before Fenix started shipping anything, from what I remember. Fenix just leads a bit with their marketing, and teasing people (rightly so) with tests from their sample rolls. ;)
I wouldn't say that's because Fenix doesn't get them first either, Fenix maybe does get them first. It doesn't mean they will be first to ship them though.
They easily could be as obviously there is no overhead time when you are just selling the emitters and very little when you are just putting a new roll of emiters where the T6 ones used to be for making the dropins.
It's just a shame that Cree dosn't mark them at all, but as obviously the vast majority of their market wouldn't need them to be marked as they are buying in bulk direct from Cree or from reputable suppliers.
