Physical impressions Fasttech Panasonic 3400 protected
21 posts / 0 new
ChangchungLeds
ChangchungLeds's picture
Last seen: 9 months 3 weeks ago
Hi, It is most a pic review of this batteries, I dont have a vernier to make the exact measurents but here I go, I just can make some comparing and test fit with my lights. Received in 14 days from china to venezuela.
Order from here
https://www.fasttech.com/products/0/10001980/1141104-panasonic-ncr18650b...
Using the code coupon BLF you get 5% discount
Well protected
Bill and box to protect the batts.
Comparing pics, is kind big, dont fit in my SD6, H600w, but fit in my ultrafire C1 and 501
Perfect fit in the i4 charger
Measurements of the 3400 batteries and some pictures comparing with others
3400 top button from Fasttech
3100 top button from another dealer
3400 Intl-outdoor flat top
I think that whoever installs the PCB should remove the original packaging of the battery to make them a little thin, but this way is left to show the originality of the battery
I will make some current test in a couples of days
They FIT in the following lights:
Armytek Predator
Jetbeam M1X
Spark ST6-460NW – The cell slides in and out easily, but not by gravity alone. The length is fine.
Ultrafire C1 and 501
SolarForce L2N host
SolarForce L2P (at least in mine)
SolarForce L2P (older, about 2 years prob)
SolarForce m8
SolarForce L2
Old style L2 with extender and MPP-1 head, though it didn’t drop in full speed due to air cushion so it’s a tight fit.
Sky Ray King
TN31 (very tight fit tho)
Fenix TK75
Sunwayman C20C “Tomahawk”
Shiningbeam Blaze
Nitecore P25
Paladin i6
Keygos KE-5
SkyRay King
Sipik SK98 flashlight
Jetbeam M2S
Jetbeam BC25
Crelant 7G6CS
Crelant 7G5CS
Crelant 7G3CS
Crelant 7G2CS
Armytek Barracuda
BlackShadow Terminator
Aurabuy C8 T6
Tight Fit for
Eye 15
Fenix TK35
EagleTac G25C2 Mark II
They FIT in the following chargers:
- Nitecore Intellicharger I2
- Nitecore Intellicharger I4 V2
- Miller ML102
- Soshine SC-S7
- TrustFire TR-003P4
- UltraFire WF-188
- Xtar SP2
- Xtar VP1
- Fenix ARE-C1
They DO NOT FIT in the lights below:
ZebraLight sc600 (too fat)
TM15 (too tall, but does work if you tighten the head like hell, not rec’d)
ElektroLumens SAR (too fat!)
FireFoxes3 (too tall AND too fat!)
Zebralight H60
SD6
H600w
ST360-CW
Cannot Fit / Too tight (fat) (but can force in and have hard time to take it out) for
Fenix E50 (Single / Double Cell). Double cell will crash the -ve end of the battery
KD C8
They DO NOT FIT in the chargers
- UltraFire WF-139
in the “USB power bank” (2*18650) that I got from eBay.(It’s the white one with a slide-in design and an orange “ULTRACELL Plus+ Smart Portable Charger” sticker, although it is sold with other names/stickers as well.)
As for Fenix PD32UE, as mentioned by other forumer, it is cause by the -ve plate is a bit raised as per pic below (right). To make it work (initially), I put a round donut ring tape (got it from notebook battery pack) at the bottom of the battery as per pic below (left). Then it will work.
But, due to limited quantity of the donut ring tape, I put it at the tail cap – spring area as pic (right). Left is the original without donut ring tape.
By doing so, I can use all 6 batteries in PD32UE.
I will update all this info if someone can share with us…
Zebralight Spark Princeton Inova Petzl Maglite Bushnell a lot of Cree XM-L Lights 18650's Intl-outdoor 3400 Panasonic 3100 Hobby Charger
Edited by: ChangchungLeds on 05/05/2013 - 23:56
Vectrex
Vectrex's picture
Last seen: 10 months 2 weeks ago
Can you give us the exact physical dimensions?
ChangchungLeds
Tomorrow I receive my vernier, I will post the size asap…
JackCY
JackCY's picture
Last seen: 3 years 8 months ago
Dimensions are on FastTech and are +-0.1mm precise I think.
Removing the original wrapper would not be good.
= unknown cell
= more work to do
+ even with that thin plastic wrap due to the protection the batteries are still too small in all my lights.
Yours are so small they don’t have 0.5-1.0mm space there around a battery?
ChangchungLeds
= unknown cell
= more work to do
= unknown cell, yes, I comment this in my review on the site, who install the PCB leave the original wrap to ensure originality
Yours are so small they don’t have 0.5-1.0mm space there around a battery? Yeap… Spark SD6, ultrafire C1, barely fit in the Zebra H600
whokilledJR
Last seen: 2 years 1 month ago
I’ve got 2 of these on order from fasttech, hopefully they fit my intended applications.
InfinitusEquitas
InfinitusEquitas's picture
Last seen: 2 years 6 months ago
I don't have any truly objective measurements with regards to how these would perform, but I have six of them right now, and they are doing just as well as the 3400mAh Keeppower batteries I picked up at about the same time.
Their one drawback is definitely the size.  They do not fit into my 1x18650 palight for example.  Otherwise they seem to be excellent batteries.
ChangchungLeds
Updated with more info
Anzycpethian
Anzycpethian's picture
Last seen: 4 years 5 months ago
Do these fit into the Skyray King or any Nitecore Tiny Monster?
"Do not Weep. I shall draw all Things which perish into myself When I am lifted from the Earth." ~ Begotten (1991)
InfinitusEquitas
Should fit either with no problems, but I can only 100% confirm that they will fit fine in the Skyray King.  At least they fit fine in the four versions I tried so far.
Anzycpethian
Thanks for the post, it helps me out. I just can’t decide between these, Orbtronic and Keeppower….
InfinitusEquitas
Go with Keeppower and buy a flashlight for the price difference.  They are basically the same.
ChangchungLeds
I just update the first post with a lot of info about some lights that can work or not with this batts… I hope that help you to make a choice…
InfinitusEquitas
You can add the following to the Will Fit list;
Jetbeam M2S
Jetbeam BC25
Crelant 7G6CS
Crelant 7G5CS
Crelant 7G3CS
Crelant 7G2CS
Armytek Barracuda
EagleTac G25C2 Mark II - Very tight fit.
ezarc
Last seen: 6 months 1 week ago
Quote:
Is it possible to short the battery like that?
skyrider1
Last seen: 2 years 2 months ago
If you look closely you can see he used some clear material (tape?).
ChangchungLeds
Jetbeam M2S
Jetbeam BC25
Crelant 7G6CS
Crelant 7G5CS
Crelant 7G3CS
Crelant 7G2CS
Armytek Barracuda
EagleTac G25C2 Mark II – Very tight fit.
Thanks… I will
Yeah, clear tape and then I put the vernier in zero
Cir2kuk
Last seen: 5 years 9 months ago
Won’t fit in KD C8.
ChangchungLeds
Cir2kuk wrote:
Won’t fit in KD C8.
Thanks
petergunn
Last seen: 5 years 8 months ago
Do fit in cheapo Aurabuy C8 T6
ChangchungLeds
Thanks
