Somewhere that i can buy fully de-domed Xml's?
29 posts / 0 new
Tiggis
Last seen: 5 years 6 months ago
Looking for fully de-domed xml leds (sealed) to buy for some nice throwing projects, does anybody if it’s possible to buy some from somewhere?
Doesn’t want to try myself, probably only gonna trash them.. Smile
NightCrawl
Last seen: 4 years 1 week ago
Maybe some private members. They are not available from factory. Gasoline works great for dedoming..
Tiggis
Gasoline When you de-dome? Put the led in gasoline?
NightCrawl
Yup. There are some fluids that work well, but it depends on the ingredients, so you cant know for sure. Acetone is not the same everywhere for example.. gasoline works slow but well.
AlexGT
AlexGT's picture
Last seen: 30 min 30 sec ago
could you explain the gasoline method?
ChibiM
ChibiM's picture
Last seen: 2 hours 56 min ago
yes, I tried to de-dome one led.. and I failed..
it did work, but I saw a bit silicone left on the edge, so took it off, and then the light didnt come on anymore
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 2 weeks ago
Check with Scaru. He can probably supply them in matched sets of 7 each. Dedomed by superheated vaporization.
Scott
Pulsar
Pulsar's picture
Last seen: 4 months 1 week ago
heheh… scaru, the man that saw the light. for a second. he was blinded by a white wall
NightCrawl
I filled a schnaps glass with gasoline, dropped the XML in it and when I looked at it 12 hours later, the dome fell of and almost all of the silicone was gone, except for a little bit around the bond wires. Dont try to scrape it off, you will kill the bond wires. Wink
AlexGT
AlexGT's picture
does gasoline affect the phosphor layer or substrate in any way?
vestureofblood
vestureofblood's picture
Last seen: 22 hours 35 min ago
I'm certainly no expert on this, but the way I do them is in an electric skillet.
I set the die in there and turn it on like I was gonna reflow but without the PCB.   About 375F is where I set the skillet.    It needs to cook a minute or two so the dome pops off easy and doesnt leave much behind.
I pull it off with a pair of hemos, you just have to make sure the wires are pointing up if your hemos pinch from the sides.
To remove what little residue is left, while its still hot I run a tooth pick around the edge of the platform ( not on the die).   Just stay away from the side where the wires are.
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
dct73
Last seen: 1 year 1 month ago
Use gasoline or acetone as stated above. No reason to hack it off with a knife or rip it off with a pliers, unless you just have to have it right now.
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
What's the octane rating?
Sorry, I had to ask.Wink
You're a brave soul, crazy, but brave. Just don't forget and drink what's in the schnaps glass.Surprised
I just pop the dome off by pinching a little with two finger nails and pull up very fast. Works pretty good so far.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
vestureofblood
I was thinking the same thing.   Kinda seems like the gas would leave a film on the die to (like when you spill it in water).
I'd like to see a controlled test done on the two methods.  Output before de-doming on each emitter then output afterward.
Tecmo
Tecmo's picture
scaru said gasoline took off some of his phosphor. I haven’t heard anything bad about using acetone, but I don’t have any so I just pry off mine.
scaru
scaru's picture
Tecmo wrote:
scaru said gasoline took off some of his phosphor. I haven't heard anything bad about using acetone, but I don't have any so I just pry off mine.
Yeah, it's been a while since I tried to dissolve the stuff off of it. I personally have found that a bit of denatured alcohol also will work fine. I'll admit I am the only person I know of to have a problem with it so I say go ahead with it and give it a shot.
Flomotion
Flomotion's picture
Quote:
give it a shot. :Sp
Flomotion
biggulp
Last seen: 1 week 5 days ago
I heat up the sides of dome with a soldering iron and gently pry it with a screwdriver. Great success rate so far.
crnkin
Last seen: 3 years 10 months ago
I soak it in petrol overnight then take it out with pliers and blow the small dusty bits of silicone off.
The dome comes off within the first hour, but its the rest that seems to take the time. It doesnt all come off at once in the petrol.
Have done heaps now, after stuffing 5 up with the heating method.
Chris
Tiggis
Seems easy.. in Sweden we call it T-Röd. Smile
MRsDNF
MRsDNF's picture
Last seen: 11 hours 40 min ago
Old-Lumens wrote:
What's the octane rating?Sorry, I had to ask.WinkYou're a brave soul, crazy, but brave. Just don't forget and drink what's in the schnaps glass.SurprisedI just pop the dome off by pinching a little with two finger nails and pull up very fast. Works pretty good so far.
I dont know if it helps but aviation fuel here has the highest octane rating and still has lead in it. If using this method it would be highly advisable to not have any ignition items close by near the fumes and that includes any naughty people that still do this, smoking.
NightCrawl
@AlexGT: accidentially left an XPG in gasoline for 3 days. Didnt hurt the substrate.
@OL: Octane rating was 95. Thats the lowest we have in Germany. Thanks for your concern, but no worries, I always test my schnaps with a lighter, if it burns, I dont drink it. Silly
@vesture: Gasoline with 95 octane vaporizes without any residues. And people did such tests.. you lose about 20-30% lumens but gain a lot lux.
@MRsDNF: We only have lead free gasoline in Germany since about 15 years.
Also, there is a difference between acetone and gasoline. Acetone dissolves the dome faster but not completely. Gasoline takes considerably longer but completely cleans the LED.
DB Custom
DB Custom's picture
Last seen: 8 hours 54 min ago
Thanks for this info. Hope I can remember this when I start my next mod. Wink
Lothar
Lothar's picture
Last seen: 1 day 21 hours ago
Thnx for the info guys!
How much +- tint do you lose when dedoming? If you want to end up with a 5000K colour after dedoming, what what tint do you need to start? 0A/0D/1A/1D?
If you dedome a XML 1A and you dedome a XML 3C, will they have the same colour, or will the dedomed XML 3C be warmer than the dedomed XML 1A?
Thnx
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
NightCrawl
Rough number: you move two numbers up. 1C->3C. 1A->3A. 0D->2D.
Not always, but thats exact enough for me.
Nightbird95
Nightbird95's picture
Last seen: 1 month 1 week ago
Thanx for all these info. I’ve just removed the MPCB off my K40 and it is now being ‘marinated’ in gasoline. I’ll leave it in a safe place and observe the results tomorrow as its almost midnight here. I just hope I’ll get positive results. Smile
I’m gonna boost the throw of my K40. J)
Slewflash
Slewflash's picture
Last seen: 1 year 8 months ago
Slewflash
benz
benz's picture
Last seen: 8 months 1 week ago
I wondered if you could buy them de-domed as well. It would be great to get de-domed emitters direct from Cree! It would save them having to put the domes on in the first place…
totilde
totilde's picture
Or we can ask them to make flat domes lenses, protection for the phosphor and same results than dedomed
Mooooooo
