My new Led light for offroad motorbike 18watts rated 6 Cree XB-D
Hi guys, I just buy this Lamp and I want to share this with you.
The lamp come in box without any wire harness kit instead others brands like Aurora or Rigid
The lamp look very well made, I cant resist to open it and see what is inside, I avoid the warranty? Maybe… I dont know if the electronics inside can resist well to vibrations.
I buy the flood model, I try to take the optic out that was very easy to do, I preffer spot instead…
The light is installed
Because I am going to use the light just some times my wife make me a cover to protect it of the dirt
I will post some night shoot later…
What bike do you have that mounted on? I’m looking at getting some of the single led versions for my dual sport.
Can you post a link where you purchased it from so we can see the specs and such. Thanks.
In my Suzuki GN125
I buy locally, almost no specs info… I buy it because a friend buy the 12 Leds version for his klr650
Take it from a ebay seller:
Power: 18 W
.Voltage: 9-32 V
.Theoretical Lumens Output: 1800 LM
.Operating Lumens Output: 1260 LM
.LED: 6pcs*3W (CREE LED)
.Beam: Spot Beam (30 degree).
(we also have 60 degree,if you want,please mail us once you paid,thanks)
.Color Temperature:6000K
.Working life: 50000 hours
.Working temperature: –40~ 85℃
.Size: 99*73*107mm
.Certificates:CE、 RoHs、 IP67
. Material: 6063 aluminum profile, stainless steel bracket, PC Lens.
. LED Light Bar Low Current Draw means no harms to battery and save gas.
. Designed To Withstand Any Condition, 6063 Aluminum Body For Strength And Durability.
. Vertical Fins Maximize Heat Dissipation,Advanced Heat Sink Designed To Prolong The Life Of The LEDs.
. Wide operating voltage range: it can apply to different types of trucks, Off-road vehicles, 4x4, Military, Mining, Boating, Farming, Heavy Equipment etc.
. The light output of these LED light bar is simply phenomenal, they produce a mass of clean white daylight (6000k), free of artifacts and focus dead spots. They light the entire forward viewing area, giving greater visibility without eye fatigue.
. Their super efficient reflector uses patented Hybrid Technology, allowing these lights to runs at 93% optical efficiency, which is unmatched in the industry. Each LED light bar consists of two rows of high intensity LEDs, each sitting in their patented reflector assembly, measuring about 1 inch square. Each LED is independent, so if one LED fails the other LEDs will not and the LED light bar still works fine.
Package includes:
2pc 18w led work light (SPOT Beam)
Necessary accessories
At 1260 lumens OTF, it seems rather underpowered for off-road motorbiking. Many human-powered mountain bikes have more lumens than this. I have a pair of XMLs on my mountain bike so OTF lumens is probably somewhere in the 1200-1300 range and I’m not comfortable going very fast off-road at night because visibility is pretty limited. I think I’d want at least 2-3 times as much light on a petrol-powered motorbike just because it’s capable of going much faster than my mountain bike.
I am pretty sure that your lights with XML Leds are not 1200-1300 lumens, in the best scenary maybe 800 lumen each, the XML led is better for flood use, the small die Leds like XPG of this one in this lights XB-D throw better… You have to check this light at night…
Oh, I wasn’t suggesting that they were 1200-1300 each. My guess is somewhere around 600-650 each for a total of 1200-1300 for the pair. I guess I should have said “total OTF lumens” in my original post. I still don’t think it’s enough light to mountain-bike safely at night but to each his own. Since it’s IP67-rated, the flood version of this light might make an interesting security floodlight for a house.
good review!
I have an 18” version of the same light. I have it installed on the front of my truck for offroading and night driving on back roads
Good idea…
Thanks
Boats? Offroad ATV?
Do you have any night shots?
Link to this product somewhere? On Ebay?
-Garry
Here you go some of them, pay attention about the flood or spot models
http://www.ebay.com/itm/261189307388?ssPageName=STRK:MEWAX:IT&\_trksid=p3984.m1438.l2649
http://www.ebay.com/itm/261189310013?ssPageName=STRK:MEWAX:IT&\_trksid=p3984.m1438.l2649
http://www.ebay.com/itm/290850309071?ssPageName=STRK:MEWAX:IT&\_trksid=p3984.m1438.l2649
http://www.ebay.com/itm/300875968379?ssPageName=STRK:MEWAX:IT&\_trksid=p3984.m1438.l2649
12 Leds model
http://www.ebay.com/itm/121050431999?ssPageName=STRK:MEWAX:IT&\_trksid=p3984.m1438.l2649
http://www.ebay.com/itm/300842633901?ssPageName=STRK:MEWAX:IT&\_trksid=p3984.m1438.l2649
No yet
Here’s a link to my review of the 18” version if anyone is interested
Great… Thanks
Sure, you just need a 12v DC power supply.
I ordered a spot one off fleabay and planning to convert it to 4x XM-L in series. Any recommendations for a power supply from a 12v battery source?
No humans within 10000 ft. radius, except rednecks :zipper_mouth_face:
Be carefull with heat concern…
Maybe this thread help you
